Xmas came early - TRD Supercharger installed
    how much $$ would this conversion cost - ?
      My estimate is about $10k for the blower and piggyback ECU fitted and tuned by your nearest reputable shop. Hardware is just short of $9k so it depends a bit on how much the shop will charge you.
        I doubt the larger wheels would make that much differance especially with the deeper diff ratios (as per sig)
        I can't see the after dyno sheet but looking at the before dyno run, the ambient temp is only 26 so if the after run was done recently I would expect ambient to be much higher, this alone along with other factors would account for some of the "loss".
        As Double_D has said it is that improvement down low that really shines with the blower and that improvement doesn't show on the dyno sheet.
        My 90 series is easier to drive off road with the blower than without due to the increase in torque down low.
        Fuel economy has not suffered (unless I use all the extra ...) plus my consumption is virtually the same from 80 km/hr to 110 km/hr.
        Lee
        Leethal
          Originally posted by double_d69 View Post
          Cruising you can't really hear anything, its only when you put the foot down she whines.... the car too
          lol....I hope the blower whines some dont but if I'm putting on a blower I want to hear it. I got quoted $10,750 to do my car and still would love to do it next year. At the end of the day its the SOTP meter (Seat Of the Pants) that counts dyno's really are tuning tools...ENJOY
            Lee
            Ratios were done ages ago back when I had 32's.. when I went to 33's It felt like I was constantly towing something... a massive power reduction. Now it feels like I'm driving a zippy car, not a 2.7 ton 4x4!
            Can't wait to tow the boat, I'm sure I won't even feel back there
            [b]2006 GXL Prado 1GR-FE [/b]- ARB Lockers & Bar, Tigerz11 Winch, snorkle, Custom Bash Gaurd & Steps, AJ4x4 Rear Bar, Spotties, UHF, Dual batt, 33" KM2s, Custom drawers, Ext Icon Coilovers, 4" SRC Shockies, Dobinson 4" Springs, Diff drop, Light Racing UCA's, Ext SS brake lines, Driveshaft spacer, Superior trailing arms, Nitro 4.56 diff gears, DBA Slotted brakes, TRD Supercharger, Bullet Ultimate Exhaust, XEDE Dual map Processor
              Will have to keep an eye and ear out for you on Fraser, will be around there new year.
              Shirl.
              2004 V6 GXL, Roo Lite,s with HID conversion, HID headlights, Dual battery(in rear)with DC-DC charger,Cargo barrier, Coupler Tec rust proofer, home made rear storage, home made heat exchanger, Oricom 80 channel UHF, front recovery points,Engel fridge(oldie but a goodie), low profile roof rack(home made), fold down table on rear door, gas rear door dampner, 265/65 BFG All Terrains, K&N filter
                Blower kit arrived today!! Itching to get stuck in but need the car for two more weeks before I can take it down for a few days. Will post pics as soon as I figure out how it works.
                  Fuel consumption with the blower
                  100% hwy driving - 16.2 ltr/100
                  100% hwy towing the boat (approx 1 ton + fully loaded car) - 22.8 ltr/100
                  100% sand driving (50/50 towing the boat full loaded/without) - 30.4 ltr/100
                  The above figures were achieved while giving it plenty of right foot (i.e. I was not driving economically).
                  All in all its roughly the same as before but with all that extra power
                    I want one!
                      Sooo, blower now fitted and bar done. Next is the suspension. Now to get used to all the new noises in the engine bay (slight rattle at idle which seems to come off the gears) and the delicious whine as you put foot The Prado runs like a steam train and even yesterday at 38C in Melbourne, it ran very strong. I'll ignore consumption on the first tank or so and report some data later. So far I'm stoked with the van !
                        Did you get it dyno tuned? Results?
                          I don't understand the inertia dyno graph as it has speed at the bottom, kW on the left (easy enough) and force on the right. I'll have to work out a gear ratio to get back to revs to figure out the torque curve. Darren (Autocraft) said it made 180 kW and 460 Nm on the wheels. A bit more than I expected.
                            what size are your tyres? what gear did they dyno in? Sounds a little high, but if it's correct happy days
                              double d69, have you got any thoughts on the plug and play pedal harness from our sponser? .. lol.. ,, nice buildup, cheers butane
                                Nice work guys....
                                Can someone kindly tell me what part number is on the blower by chance????
                                What ecu plug in did you guys use?
                                Terry
