amts' 120 Grande V6
  • #61
    Love the light strip under the awning, looks like and bright. Where did you order the LED's from?
    • #62
      They were from ebay. Came as a strip 5m long. A word of warning though as I cut a short strip of 0.5m to use as a night light for inside the house. After a few months, the LEDs started turning brown and the "silicone" that surrounds the LEDs were also turning brown.
      So far on the awning, there are no problems. It gets left on for maybe 2 hours at a time. Perhaps being glued to the aluminium extrusion of the awning and the fact that it was cool when we went camping probably helps with heat dissipation.
      • #63
        Made an attempt at installing the recovery points. Here is the passenger's side.
Name:	Prado Recovery Point.jpg
ID:	648312 Click image for larger version
Name:	Prado Recovery Point - shackle.jpg
ID:	648313 Click image for larger version
Name:	Prado Recovery Point - shackle 2.jpg
        Driver's side to be done at another time.
        • #64
          Also installed a transfer case bashplate. This version also protects the actuator box
Name:	Prado transfer case top 2.jpg
ID:	648317Click image for larger version
Name:	Prado transfer case 1.jpg
ID:	648315 Click image for larger version
Name:	Prado transfer case 3.jpg
          • #65
            OK I will bite. Where did you get it?
            Greg - 08 D4D Prado,
            • #66
              It's my design, got refined along the way and ended up with this.
              • #67
                Hi AMTS, I was just wondering if there has been anymore developments with these point?
                Thanks Matt
                Rig build here
                • #68
                  Playing the waiting game at the moment. The 3 point version isn't ready yet and the 2 point version has been submitted for quote.
                  • #69
                    No worries, please include me in your first batch of the 2 point
                    Thanks Matt
                    Rig build here
                    • #70
                      Moved the QuickFists (aka shovel mount) under the Pioneer Platform for more clearance into underground carparks.
                      amts
                      Ninja Poster.
                      • #71
                        Andrew be careful of the rubber strips if they have been in the sun I have had one of these fail and a few of the other Rhino style. I now use occy straps and I throw a couple of cable ties over the shovel. Might be our overly aggressive ultra violents up here
                        • #72
                          No worries. Will keep an eye on it. So far so good.
                          • #73
                            Fitted an organiser tray for the center console fridge. It's a perfect fit with a fairly deepish tray.
                            Separate thread here http://www.pradopoint.com.au/showthr...912#post568912
                            • #74
                              Oh, so is this the dairy compartment?
                              • #75
                                I guess you can put it that way. Crisper is underneath.
