amts' 120 Grande V6
  • #76
    Christmas in July. Got some awesome gear fitted:
    Whiteýs custom valved Ironman Foam Cell Pros
    King KTFR-101 front springs
    AMTS 120ABMD rear airbag to coil conversion springs
    Front swaybar relocation plates
    Rear adjustable extended swaybar links
    While doing the front struts, realised that the strut tophats on the Grande is shallower, about 15mm shallower as measured by Whitey. So swapped these out with GXL tophats (thanks to photoprado)
    amts
    Ninja Poster.
    • #77
      Fitted Goodyear Hybrid wipers from Costco
      • #78
        After 6 years, winter has finally taken its toll on the old battery. Replaced with exactly the same one - Supercharge Gold MF80D26L
        • #79
          Hi,
          I also have a Grade 2005 though.
          My first up grade will be the suspension.
          Do have any pics of your new suspension set up?
          • #80
            Originally posted by Cant-Touch-This View Post
            Hi,
            Can you see the photos on post #76?
            • #81
              Na, it says sign in with your google account?
              • #82
                Please have a look again.
                • #83
                  There they are, cheers.
                  What made you decide to move away from the bags?
                  • #84
                    See my sob story here http://www.pradopoint.com.au/showthr...l=1#post574191
                    [violins playing in the background]
                    • #85
                      Do you need longer bolts to use the front swaybar spacers?
                      • #86
                        The bolts come supplied with the spacers. You can't reuse the factory bolts.
                        • #87
                          Hey AMTS are the swaybar spacers and rear links your products?
                          • #88
                            No. They came as part of the suspension group buy.
                            • #89
                              I put those on my 120 too, and on my falcon, about a year ago, and I found they were pretty crappy.
                              • #90
                                Changed the rear pads and rotors as the brakes were squealing when going in reverse only. Turns out one of the caliper sliding pins are sticking a bit and causing uneven brake pad wear.
                                New pads (genuine) and rotors (DBA 793SR & 793SL) fitted and Bendix Ceramasil used to lubricate the slider pins and backing plate
