Battery Monitoring - Prado 150
  • Battery Monitoring - Prado 150
    Hey guys
    I was just wondering if anyone can recommend a battery monitoring unit? Needs to be fitted inside the 150 and not under bonnet. I am not interested in the Redarc BMS at this stage. All i require is a display that can give me both readings for AMPs and Voltage of both primary and auxiliary batteries and can be easily mounted.
    Thank you
    George
    2012 Silver Altitude Prado T/D Auto, King Springs 2" Lift with 'H' Front Springs, Deluxe Color Coded ARB-Bull-Bar, Winch, Lightforce 240 XGT's HIDs, Safari Snorkel, Outback Ideas Recovery Points, ARB UBP, Cooper S/T Maxx, Hayman Reese Towbar, Dual Battery (Redarc 40amp BCDC), Sandgrabba Mats and Cargo Mat, UHF Ariel, Portable Uniden UHF Plugs Into Ariel, Mounted ARB Compressor, [B]TG150[/B], ARB Fridge/Freezer 60L.
    If you can live with volts only, ABR make a decent unit.
    Measuring amps gets expensive. The measureing devices I've seen need to be wired in series with the positive lead. I've not seen a wrap around unit yet. You'll also need to do a rewire of the main battery positive terminal to split the alternator and fuse box connections to measure actual battery draw.
      Here it is George http://www.sidewinder.com.au/page161.html
      Piranha Offroad make one also... http://www.piranhaoffroad.com.au/library/product/lg/dbm3d.jpg
        Also the Projecta make one, where you see both batterys at once
        http://www.projecta.com.au/Products/...VoltMeter.aspx
        [B]Robert
          Try this, pretty easy to make, costs less than $20, and you have a small, dual battery meter.
          http://www.pradopoint.com/showthread...r-less-than-30
          My Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
            I have this and reckn it's the best by far.
            Download the manual and you'll see why.
            Kowolski
            2012 Kakadu
              Mine is great....
              [CENTER][B][U]Matt
              [/CENTER]
              [SIZE=2]
              [/SIZE][CENTER][SIZE=2]
              [/SIZE][/CENTER]
                IMO, the best monitor is the one which looks the most factory. they all essentially do the same thing.
                The projecta one prob gets up on that front, but I'm even not all that convinced with that.
                  I agree that ABR make a really good unit.
                    Thanks for the feedback guys. I will check out all your posts and do a little bit more research.
                      Baintech are a good option too, while this is the 120 dash, gives you another option.
                        Decided to go with
                        1. BAINTECH Voltage & Voltage Meter Flush Mount - Mounted to the front of the vehicle for dual battery visibility
                        2. BAINTECH Voltage & Amp Meter Flush Mount - Mounted to the rear of the vehicle to display amps drawn and voltage indicator for auxillary battery
                        Cheers...
                        George
                          George, where are you going to mount the Baintech flushmount in the cabin?
                          Robert
                          Originally posted by georgev View Post
                          Decided to go with
                          Cheers...
                          George
                          [B]Robert
                            Hey Rob
                            Have a look at Matts pic in this thread. I am thinking in the same location. To the right of the HR-LR dial.
                              Hi George,
                              I recently purchased a Victron BMV-602S. This gauge monitors the AMPs like a fuel gauge and usually monitors your second battery. THe 602s can montor the volts from both your batteries and is relatively simple to install as they have provided a shunt with an RJ45 conector. Go to http://www.victronenergy.com/battery...nd%20bmv-602s/ to get more info. As someone mentioned above, they aren't cheap - mine was $294.
                              Good luck
                              1998 GXL Prado, OME 2" lift, firestone airbags, BFG tyres, ARB diff locks, Recarc duel battery, 100amp hr Gel battery, Fyrlyt spotyie , LED Driving lights, 35watt HID upgrade headlights, Outback draws, Tigerz11 Thumper compressor, air tank, TPMS, GME UHF, Vitron BMV-602s bat monitor,sand grabber floor mats, front/rear/centre dif breathers, Heavy duty clutch, unichip, extractors, 2.5" exhaust.
