I've just had a 2" Lovells spring upgrade done, on top of existing Bilstein shocks upgrade done 18 months ago but still in good condition. The end result is fantastic with plenty of extra clearance both front and back. I had HD springs put on the front to carry the extra weight and standards on the rear with polyair bags for when we load up and go camping. The steering is now way more responsive and the car doesn't dive and roll into corners.
Before:
Front Left: 750mm
Front Right: 740mm
Rear Left: 820mm
Rear Right: 800mm
After:
Front Left: 805mm
Front Right: 820mm
Rear Left: 850mm
Rear Right: 860mm
There used to be a lean to the drivers side which has now been corrected albeit it now leans a bit the passengers side - damn KDSS - but I've been told it will settle over the next couple of weeks. I'll post up some measurements then to see how it has settled. Also to note is that I'm riding on 18" wheels so the measurement will be approx 13mm more than those on 17's.
VXWesty
Before:
Front Left: 750mm
Front Right: 740mm
Rear Left: 820mm
Rear Right: 800mm
After:
Front Left: 805mm
Front Right: 820mm
Rear Left: 850mm
Rear Right: 860mm
VXWesty
