Smithy's Rig Build
    Thanks Smithy. Do you reckon these would fit? Haven't seen this shape before. Is the T10 receptacle orientation correct for them?
    http://www.ebay.com.au/itm/10-T10-Ca...ht_3421wt_1121
    I wonder if the disc can be swapped around if the polarity isn't correct. Otherwise the light would be shining into the door!
    Love the product description...
    LED. Not as in LED Zeppelin the musical phenom since forever. But LED lights. Bright without giving off heat. This means energy savings which is another way to describe money savings. So you have lots of money left over to go see a picture show. Make take your sweetheart. Box of popped corn and fizzy soda. This particular LED bulb comes with a T10 base and has 24 individual 3528 SMD chips on it for warm white like waking up after a Sunday afternoon nap. After brunch of champagne and blueberry pancakes and smoked salmon. Pick up a bunch today.
      OK, so maybe these ones then... T10 Cree. If they don't throw the right spread of light, they're going in the parkers
      http://www.ebay.com.au/sch/i.html?_t...at=0&_from=R40
        They should do the job nicely!
          This is not quite right - the door lights are quite different on the 150, by the looks of things.
          You need to release the top clip on the light cover gently with a screwdriver, and then prise the cover and the light housing from the front end of the unit out of the door, releasing the metal clip I have circled in the second photo. Sorry the photos are not very clear, but my camera isn't suited for macro shots. Hope this helps.
          Thanks Smithy. Between your shite photos and my shite eyesight it should make for 2 broken light units.....
            Sort of followed those instructions (actually read them then attacked the light with a screwdriver to prise it out, 'cause Smithy said it could be done) and all came out OK.
            Now that I know it can be done, just got to get the bulbs and go for it, now that I've got the ceiling interior lights done.
              Right, MLC - just for you, I have re-done the images (first had to take the light out, disconnect the power, reinstal the light, and pretend I needed to pull it apart so I could get some more shite shots without the blue haze).
              Step 1 - gently unclip top of the light cover with screwdriver. Step 2 - insert screwdriver in front section of light and prise entire light housing out. Step 3, I am sure even you could take it from there... - Good Luck!
                Thank you Smithy.
                I owe you a beer (and really do appreciate your effort)
                Now, re the beer, get in line behind Rev.
                  Thank you Smithy.
                  I was goin' to say........................
                  Still waiting?????????????????
                  I think all of this stress from mlc reneging, I will be having my own mid life crisis.
                    So do you guys have to wait until mlc visits Townsville and Tassie to collect on the beer, or have to get to SA some how for it.
                      I reckon it's just easier to brew my own! Got one on at the moment - ready for bottling on the weekend hopefully!
                        Smithy,
                        Thank you for your most helpful post. I have continued my search for LEDs for the door over on this thread
                        http://www.pradopoint.com/showthread...l=1#post406867
                          Let this be a warning to others, when MLC takes an oath to purchase beers for them......................I was in South Australia and I can tell you one thing.
                          Sth Aus is a very, very, dry state and MLC isn't doing anything to help in that regard.
                            Isn't there a pic of him relieving himself somewhere in this fine dry state of ours?
                              It would only be in the interest of keeping some form of weed alive.
                                Blah, blah, blah. I'm not reading any of these b/s posts. Smithy, my apologies for this riff raff mucking up your thread.
                                mlc - caring for the innocent members of PP
