Grande Sat Nav 2007 - Microphone
  • Grande Sat Nav 2007 - Microphone
    Hi,
    We have a 2007 Prado Grande with sat nav model PZQ60-00200, 08545-00910 (or one of them at least according in the manual). When trying to use the phone mode it is unable to pick up our voices. From further reading on the sat nav manual it would appear there is suppose to be a switch and a microphone on the steering column. We have the switch but no microphone. Is that correct? Or would it be somewhere else?
    If the microphone is missing as I suspect can anyone suggest a good shop in Brisbane area to get one installed?
    Thanks in advance for your help.
    Regards
    Bonnie
    Similar thing happened to me. Found the microphone came loose at some stage, and was hanging inside the dash.
    If you open your steering wheel column, you will probably find yours too.
    Rudie
    2007 Prado Grande
