Fitting an aftermarket radio
  • Fitting an aftermarket radio
    Does anyone have a radio wiring diagram for 08 120 series with steering wheel control. I want to fit a Sony aftermarket head unit. Thanks in advance.
    If they supply a 'Toyota adaptation harness' that should take care of it for you.
    My after market radio went straight in.
    2[FONT=Arial Narrow]008 Prado GXL D4D Auto with Prado Pack
    4x4 History: 2000 Prado GXL 90 Series 1KZ-TE, 1992 4runner 2.8 Motson turbo, 1985 Landcruiser 60 Series 3.9L Diesel, 1985 4Runner 2L 2.4 Diesel later mod. + 2.4T (Factory Turbo), 1982 Hilux 2.2L Diesel in Yellow (callsign 'Yellow Peril') later mod. + 2.4L engine[/FONT]
      You may also need a separate adapter module for the steering wheel controls - My Alpine did.
      ....... more to come .......
        aeropro ones at supercheap should suit, i got one for my 04 120, no steering wheel controls though.
        looks like you need one of these (I think)
        http://www.supercheapauto.com.au/onl...d=105593#Cross
        and one of these (I Think)
        http://www.supercheapauto.com.au/onl...id=11550#Cross
        With you two you are up for about $35 to be safe, not sure if this is cheaper than toyota?
        Beats cutting and soldering (which is what I previously did), so quick to install, no errors with wires falling apart later and touching/short circuiting and easy to change brands in the future if needed. Just unplug and get the right plug.
        prado2004
          Hey Prado2004,
          Are those wiring harnesses specific to one brand of stereo?
          I'm looking at the Alpine AVH-X3500DAB and trying to get a wiring harness to be able to plug straight into the existing Toyota plug. Guess I'll head down to Supercheap and check out their range.
            Check out this guy: http://stores.ebay.com.au/atcaraudio
            I got the Prado fascia surround, TOYOTA to ISO harness, and ISO to PIONEER harness. Should mean plug and play when the headunit arrives.
