3rd row seat removal
  • 3rd row seat removal
    I've been looking around and can't find a thread for removal of the third row of seats in the 150 series.
    I recently removed my seats in about an hour (taking my time) and will post step by step (with photos) soon, unless someone can point out a thread where this has already been done.
    Drifta drawers to go in!
    Cheers, Jack
    Step by step instructions with pictures
    Step 1 - Remove the rear tie down anchors (one on each side, use a flat-head screwdriver to lift the cover flap & remove the 10mm bolts, the anchors are now loose)
    Step 2 - Remove both side covers (these will lift out with a bit of effort)
    Step 3 - Remove the six 10mm bolts (silver) that hold down the cover frame (two left side to base, two right side to base and two top [shown in photo])
    Step 4 - Remove the three 10mm black bolts that connect the cover frame & plastic rear panel
    Step 5 - Set the 3rd row seats up (ready for sitting)
    Step 6 - Remove the four 14mm bolts that hold the seats down at the rear (two per seat). These were in pretty tight! Four silver bolts in photo
    Step 7 - Remove the four 14mm bolts that hold the seats down at the front (two per seat again, use a flat-head screwdriver to lift the cover)
    Step 8 - The seats are now loose. Move them forward to loosen & remove rearwards
    Step 9 - Replace all eight 14mm seat bolts (the rear bolts keep the car dust & water free)
