Spilsy's 2013 White GXL Build Up
  • Picked up some 5/16 T Nuts and matching eye bolts from Bunnings and installed them today:
    Need to work out a way to protect the carpet around the holes now.
    Spilsy
    Spilsy
    • Today I paid a deposit for my 2" OME lift.
      The parts list:
      • Front Coil Springs (1 pair x 2885)
      • Rear Coil Springs (1 pair x 2889)
      • Nitrocharger Sport Strut (2 x 90010)
      • Rear Nitrocharger Sport Shock (2 x 60080)
      • Shock Absorber Stone Guard Kit
      • New Front Bushes
      • Packers as required
      I'm looking forward to getting up off the ground a little.
      Spilsy
      Spilsy
      • Over the last 2 days I have set about tidying up a couple of electrical items. First was the driving light harness - I never liked the way the Toyota Dealer left the cables, so I bought some split conduit and tidied up the whole lot. Annoyingly, every cable had been shortened to just the right length, meaning I couldnt reposition things the way I had originally wanted to. I also re routed the UHF Antenna cable through the engine bay.
        In the cabin, I fixed up the UHF mic. connector in the centre console, it had started to sit at a funny angle. I pulled out the console pieces/trim and re-did the cable for this to make it sit more flush.
        I have also installed some LED strip lighting into my Awning - Photos will come when next I camp.
        Spilsy
        • Hi Spilsy how have you found the volume coming out of the UHF in the centre console.
          Roy
          2012 TD GXL - Genie 3inch Exhaust System, ARB Deluxe Winch Bar & Steps, OME 50mm Suspension, M/T ATZ P3's, Safari Snorkel, ARB UVP, Redarc Dual Battery System with Optima D34, Custom made rear draws, ARB 60L fridge, IPF 900XS lights, ARB Air Compressor, Tigers11 Roof Rack & Awning.
          • Originally posted by ROY07 View Post
            Roy
            Roy,
            I have the unit turned up to full noise and can hear it clearly even with the radio on (not loud).
            Ideally I'd have a remote speaker, but its not really been an issue.
            Cheers.
            Spilsy
            • What was the OME kit worth if you dont mind me asking Spilsy?
              • Originally posted by topic97 View Post
                In the end, the bill will be $1737.
                Lucky me though, as my lease will eventually pay for this, I will only pay about $800 (after the lack of GST and my income tax savings)
                Spilsy
                • how do you get your lease to pay for that ? is it a novated lease ? I thought they only covered maintenance and keeping the car running ?
                  • Originally posted by maulbeagle View Post
                    It is novated, and this is maintenance. My current gear is getting to the point where it is no longer capable of doing its job. Hence a replacement is required. The replacement is just better than the stock gear.
                    Spilsy
                    • ok. how old is the car and how many kms ? I may have to try this one as well !
                        I was encouraged to do this by a colleague. He said that as long as I don't mention that its a lift, just a replacement of worn out components, it would be fine.
                        This is what I sent to my lease company:
                        It has become clear that the suspension on my Prado has started to sag and is struggling to keep up on rough/dirt roads making the ride uncomfortable, and potentially dangerous.
                        My Prado's done ~75k and is 2.5 years old. It has a steel bar which has started to cause the front to dip severely under brakes. So, its time to replace.
                        I havent got a quote from toyota for a genuine replacement, but I suspect it would be about the same as the OME gear.
                        Spilsy
                        • Originally posted by Spilsy View Post
                          The parts list:
                          • New Front Bushes
                          Got the call today - I'm booked in for my OME fit up on the 7th August!!
                          Cannot Wait!
                          The Before Measurements:
                          • Front Driver: 755
                          • Front Passenger: 750
                          • Rear Driver: 793
                          • Rear passenger: 793
                          Spilsy
                          Spilsy
                            Cannot Wait!
                            • Front Driver: 755
                            • Rear Driver: 793
                            It's done...
                            After measurements.
                            • Front Driver: 795
                            • Front Passenger: 795
                            • Rear Driver: 842
                            • Rear passenger: 840
                            Spilsy
                            Spilsy
                            • What's going on with the rear??? (were you parked on level ground?)
                                It's a typing issue. All fixed now.
                                Spilsy
                                Spilsy
