  • Got the new prado a little dirty at the power lines in mundaring.. seen a few other prados up there too not sure if they are members ??
    was with my brother in-law he has a 76 series with 35s and 4 inch and I got most places he did apart from
    masssive bog wholes wich would
    be silly to go in anyways !
    but him and I were really suprised about how good the car preformed straight out of a factory !
    • just dropped the car off to get the brakes done and sway bars bushes replaced.
Name:
ID:	745236Click image for larger version
Name:
ID:	745238 Well had the prado for a few months now and been trying to do stuff slowly and do trips also,
        i had wired up a second battery with 6b&s to the rear I am just charging the deep cycle from my 240 charger and putting in car when we go on trips until I get a dcdc
        also put Anderson plug in rear for fridge and cut the cig plug off the Waeco and put a Anderson also, able to get almost 3 days on the 105 ah battery
        few photos, one if battery, black diamond lake next to the father in-laws 120, Wellington national park and also winibinga beach with a few other Toyota’s !
        Gurilla
        • I made a ceiling cargo net:
          More details in my build log here: https://www.pradopoint.com.au/forum/...296#post745296
Name:
            Started making a false floor to mount fridge slide takes up a lot of room the fridge slide and looks like it’s going to be right on top of the bolts to attach to mounting holes in back of seats so would have to take off and on the slide each time I take out the false floor
            • Click image for larger version  Name:	 Views:	1 Size:	9.3 KB ID:	745681
              Had a muck around seeing how I’ll mount my uhf under the Centre console area, have purchased a rj45 switch blank whatever there called.. will be just connecting mic into this and having the box hidden..
              looks nice and factory, just can’t hook it up yet as I don’t have anywhere to permanently mount the antenna currently using a rhino rack foldable Antenna bracket on top of the roof racks and have wired the uhf box currently to a cig plug so I can remove it until hard wiring
              Gurilla
              • I got the windscreen replaced by Novus this morning.
                • Car serviced and had both batteries and lower shock bush's replaced.
                  • Walked passed it 4 times today looked at it gathering dust, only gets driven on weekends sometimes and half a tank of diesel lasts about 3-4 months.
                    • Originally posted by Gurilla View Post
                      Any pics of what the antenna on the Rhino Fold Down bracket looks like?
                      2010 Prado 150 GXL Diesel, Cooper AT3, ARB compressor, Catch Can, Redarc BCDC 1225, Projecta DBC150, Optima YellowTop and RedTop D34, Pioneer Backbone Platform
                      • Has it in this photo if you can see it.. antenna just a cheap one that comes with uhf set
                        • Only had it a few weeks. Been learning how to drive it (only had an 80 series for a few months prior and no 4wd experience at all).
                          So far LED conversion and Kings throttle controller (V6, not diesel, yes I like it, prefer sport setting).
                          Low/high beam (Stedi Copperhead), parkers, front and rear indicators, reverse lights, all interior except vanity lights (eBay kit). Just have mirror indicators and brake/stop to do, plus the lights in the bullbar.
                          Adjusted the shocks it came with, BP51s, and two fronts are now being replaced due to a knock (warranty and apparently known issue).
                          Winch and air filter in the post. Exhaust being discussed.
                          Lots of pics in my build thread.
                          'Dan'
                          • Got the wifes Prado back from getting a remap done at just autos, not bad safe tune made 161.9hp/468.6nm of tourque. Has snorkel and standard exhaust. Got it done for towing purposes happy with the result has made a massive difference. highly recommended
                            • Finally got around to fitting the new springs.
