Here's the thread http://www.pradopoint.com/showthread...tyres-and-rims
If there is one modification that makes me nervous at the thought, its a transmission cooler...I would hate to have an ATF leak or a hose come loose or whatever...but I can see the need for it....I only ever got 1 ATF over temp indication, and that was when towing a camper trailer up teh beach, in the soft sand, and forgot to select "S" mode...I immediately stopped and idled the car for 15 mins or so.
I admire those folk who have done this modification, and as for those brackets made by Tin175, wow, well done!
I wonder if the auto over-temperature issue is will prove to be a problem with the new 2.8l "GD" engine/6 speed gearbox combination? I hope not!SE Qld: GX 150GD Auto, (Feb'16 build): TJM T15 steel b bar, 9,500lb TORQ winch, TJM s steps, Rhino Pioneer Platform (42102B 1928X1236mm), front recovery points, Wynnum towbar, P3 brake controller, TNN Underbody guards, UHF, TREKtable & LED striplight, Custom Fridge & Drawers, Waeco CFX50, 9inch illuminator 160W LED spots, 40mm lifted Dobinson Suspension (Zordo's), ScanguageII, 30 Sec Wing Awning
Started to make an insert for my USB and dual Ciga plugs that run off the dual battery
Prep 1
Prep 2
Expanda Foam
Will post once i finish it all up
2012 Pearl White VX, 3.0 Litre D4D Auto, Wynnum 2.5T Tow Bar, OME Lift, TJM Airtech snorkle, TJM diff breathers, Redarc EBRH, Projecta DBC100K, Lightforce XGT, EBC Nudge bar, Custom Recovery Points, TG150, ARB compressor, Pioneer Platform, Kaymar #K7123 /CDQ2195, 697 A/T's, Tin's DC trans cooler, MaxTrax on TraxRax, TJM DBS, Piranha Tray...
Originally posted by Rooballer View PostGot the suspension done at Zordos - great advice and a fantastic job.
Can't recommend highly enough.
What shocks and springs did John install for you?
I'll be visiting John again in the new year...he did my first Prado suspension lift...spot on!
Originally posted by Wagon Man View PostHow many KLM's VZSS?
Original injectors too...
