Is there a way to check if these are seized without tearing everything out? The wheel alignment is already out (I'm assuming from the buggered bushes) so I don't mind fiddling with these just to see if they are usable.
Lower control arm bushes. Am I being fleeced?
Undo the lock nut and see if the adjuster spins/rotates. The front adjuster is 26mm and rear is 19mm from memory. Locknuts 19mm. Make sure you mark the bolt so you can put it back the same place.
Not a hard job to do once you've done a few. Shouldn't take more than 1.5 hours a side. The front lower control arm bushes are generally the first of any suspension bush that wears/splits. It is afterall the component of the suspension that cops most of the force of any bumps and weight of the vehicle. They will prematurely wear if the suspension system is not relaxed after a lift.
I have seen bushes (genuine only) on Prados which after been pressed in actually fall out of the control arm locating hole. If you compare a genuine bush with a superpro bush you will quite clearly see that the genuine bush is only held on by about 10mm of the bush shell in the control arm, whereas the superpro is 100% contact the whole way through the control arm hole for the bush (hope I haven't confused you). IMO genuine bushes are the way to go.
Originally posted by sunny120 View PostIMO genuine bushes are the way to go.
Or am I wondering into Diesel/Petrol, BFG/Cooper territory with that question...2008 GXL Diesel Prado | Redarc Dual Battery System | OME Suspention (2883, 2895, 90021 and 60112) | LeighW Voltage Booster | Sony AVX-601BT Headunit
Originally posted by demomanca View PostIs that a ride comfort thing? From how I understand your explanation, the superpros seem to be a better made fit. Being poly with lifetime warranty, given it's one of the main wear points in a car, wouldn't that be better than a rubber bush?
The rubber having more flex is of no consequence in a Prado front end. The shocks and driveshafts limit the travel, not the bushes.
130k's is low to need your bushes replacing. On average most see around 200k's out of them.
I recommend the rubber purely for the ride quality.
Regards, Jason.
Originally posted by wholesalesuspension View PostThe rubber having more flex is of no consequence in a Prado front end. The shocks and driveshafts limit the travel, not the bushes.
Regards, Jason.
Ended up with OME, and SuperPro bushes. Getting installed today
https://fbcdn-sphotos-f-a.akamaihd.n...41950041_n.jpg2008 GXL Diesel Prado | Redarc Dual Battery System | OME Suspention (2883, 2895, 90021 and 60112) | LeighW Voltage Booster | Sony AVX-601BT Headunit
I would be making sure your bushes are stuffed first. I replaced the front end bushes myself (in my home shed) as the front camber/caster adjusters were seized. Its a 2003 grande done 285k km's of hard yakka on the rough stuff. The bushes themselves were still reasonable (until I attacked them). I also fitted new springs and struts (Pedders) and all Pedders bushes (nolathane). The ride quality/harshness, is very smooth. It was a bit stiff to start with until we did the Anne Beadell, that loosened it up on the corrigations.
I've seen plenty of so called "stuffed" bushes when they were perfectly serviceable.
I got to see the bushes before they were oxy'd out. They would have probably lasted a bit longer, but they weren't great either. Happy to have it all done now. Just need to wait to get a wheel alignment, as it feels like it's running about 10° toe out at the moment
Sent from my SM-P605 using Tapatalk2008 GXL Diesel Prado | Redarc Dual Battery System | OME Suspention (2883, 2895, 90021 and 60112) | LeighW Voltage Booster | Sony AVX-601BT Headunit
Originally posted by demomanca View PostI got to see the bushes before they were oxy'd out. They would have probably lasted a bit longer, but they weren't great either. Happy to have it all done now. Just need to wait to get a wheel alignment, as it feels like it's running about 10° toe out at the moment
You'll have to post up some finished pics.
Regards, Jason.
Hi all, interesting read here. I recently had my lower control arm bushes replaced as I was having trouble getting/keeping a wheel alignment. From a reference here on PP, I chose to contact an independant tyre dealer to assess the alignment. He called me and said the bushes (both sides) were stuffed. So for around $700, I had parts replaced, fitted, and aligned. I was pretty happy with that and his explanation was good IMHO.
The really neat part of this exercise has been the "clunk" I would hear going from forwards into reverse at slow speed on uneven terrain has also disappeared, this is due to the new bushes and tighter tolerances. From memory they were rubber bushes.
Hope this info helps others.
Cheers all.
Tim.2007 GX, Gold colour, Koni raid shocks, Kings progressive springs, polyair red in rear springs; 2" lift; MT ATZ 5 rib tyres. RanOx unit, home made rear storage system.
