Page 1 of 7 123 ... LastLast
Results 1 to 12 of 78
    Out of control poster! Anth120playdo's Avatar
    Jun 2012
    Melb this minute elsewhere in OZ the next
    5,222
    2014 PP GTG POST Trip maintenance.
    Just spent a few hrs checking & servicing the old girl.
    Just thought I would post my recommendations for a post trip check etc. In particular the gtg in the Vic high country & rivers.
    In no particular order or priority:
    Change rear diff oil. The rear LSD does a lot of work on those hills & also then gets a fair dunk in the rivers. Especially if you don't have breathers.
    I don't have aftermarket breathers, & after all the reccies & trip there was still no water in any of my fluids. However the rear diff oil looked well used, this is standard.
    This is what I use in Prado rear diffs
    Check auto trans for water. If I had an auto after all that hill climbing & risk of water getting in I would change the auto fluid.
    I changed my gearbox oil & transfer case oil. Gearbox oil was used & transfer case oil similar to new, this is standard.
    This is what I use in Prado gearboxes.
    It is recommended to lubricate your propeller shafts after water crossings. You have done a lot of water crossings.
    There are 3 grease nipples on each shaft.
    Check your tyres for severe damage. On tracks like billy goats its possible for them to get very cut up.
    Check your fuel tanks for damage.
    Visual check all nuts & bolts. Check Bullbar mounting bolts with a spanner. Check bottom of front strut nut, with vehicle on floor 19mm should be very tight. Check top of rear shock nut if no nylock is fitted.
    Usual under bonnet fluid level checks. Check & clean air filter.
    I will come back & edit as I remember things I forgot.
    Cheers, Anth - Technician
    Prado 1kd-ftv D4d specialist
    SYDNEY trip in April
    FRESH Injectors @ 120,000k, ONLY use NEW DENSO & pipes
    NO CHIPS NO TUNE UPS - piston crack risk it - feeling lucky?
    Senior Member braddo's Avatar
    Oct 2010
    Dee Why, NSW
    452
    Don't forget to check the wheel nuts!
    Cheers, Brad
    2007 GXL, Dune, D4D 6 speed manual. Satnav, towbar, Sahara Bullbar, Bridgestone D697's, Cargo Barrier, Stebel Truck Horn, Couplertec Rust Protection, Safari Snorkel, Polyair airbags, Blue Narva 175's, VMS Touring 700HDsII, GME TX3340, Tough Dog 2" lift with adjustable shocks, ARB rear air locker.
    Advanced Member CaLLaN 52's Avatar
    Apr 2011
    Berwick Vic
    550
    Took 2 days to clean mine properly, had big ding in rear fuel tank guard, removed and bashed out in 2 places, then resprayed, small dent in fuel tank where the biggest dent was, but all good! Have yet to check/change fluids
    Steve J
    D4D 09 OME Suspension/ARB Winchbar/Safari Snorkel/IPF Spotties/Cooper ST Maxx Tyres/9000LB Tigerz11 Winch with Dynema Rope/GME Remote head UHF/Sheepskin Seat Covers.....Next on list Dual Battery Sys...In Dash GPS...Rear Diff Lock
    Addicted PP Member fido666's Avatar
    Mar 2011
    Melbourne
    3,922
    Think I will have a few dings to get out too Steve. The front bash plate took a bit of a hit and there's another smaller one in the rear tank guard.
    Had front and rear diff breathers fitted before we did any of the water crossings Anth but I'm guessing the rear diff oil should be changed anyway? We run an auto and it doesn't have an aftermarket breather fitted. Is there much involved in changing the transmission fluid on a 150? I seem to recall reading there was.
    I don't think the transfer case oil has ever been changed, certainly not during our ownership of the vehicle.
    The brakes will need some attention no doubt, there was a squeal coming from 1 rear corner (noticeable mainly when reversing) before the GTG and it's worse now.
    We have a maintenance service due now anyway going off a 6 monthly schedule. By the book it's the 80,000K service but by the odometer it's only the 60,000K service. Other than the aforementioned items is there anything special we should be asking for?
    Kaka Latte Club SWMBO
    2009 Toyota Prado 150 Kakadu V6 Auto, TJM T13 steel Winch Bar, Tigerz11 Grande 12,000lb winch, IPF 900XS spotties with HID globes, Uniden 7760NB UHF, BFG KO2 265/70/17 rubber, Dobinsons C59-726 front springs, Roadsafe Recovery Points, Bushskinz Bash Plates, Rhino Pioneer Platform, Roo Systems Awning, Traxrax.
    Jun 2012
    5,222
    Quote Originally Posted by fido666 View Post
    If you are taking it for Toyota dealership servicing, they can take care of it. Diff is usually every 40k but in offroad use I say every 20k or whenever you think it might have water in it. $30 worth of oil & a d.i.y or cheap job, good insurance for your diff.
    Auto I would recommend oil change every 50k, it probably won't have water in it, but again good insurance.
    Transfer case should be ok for every 40k breather is a bit higher & they stay clean.
    Mar 2011
    Melbourne
    3,922
    Yes we take it to a Toyota dealership for servicing (have to for our Extended Warranty). I've gone back through the service invoices from when it was new and there is mention of changing the front and rear diff oil and inspecting the auto and transfer case oils at the 40,000K service (before we owned it). I can't find any mention of it since though.
    Avid PP Poster! foxclan's Avatar
    Jul 2008
    Adelaide, SA
    1,238
    Hi all
    Hope everyone had a great Easter and a safe return after the GTG.
    The Foxclan is still on tour and enjoying some great sights around Victoria.
    Good idea for a thread topic Anthony, thanks for the suggestions
    The many water crossing encountered on the High country GTG has outlined the need to replace some squeaky serpentine drive belt idlers before total falure.
    Thanks to VKPrado and Playdoh96 for their assistance with some toolbox in a can (CRC & RP7) to quieten the offending bearing down.
    Yes the Bridgestone 697,s have a few nics in them, I would have liked to have had mud terrain tyres fitted before the High country trip but running low twenties (psi) got us over most obsticals. Muddies next time!
    Main fuel tank gaurd needs a little tap back into shape just to clear it off the tank..
    Will check those fluids Cheers Anth.
    Got the standard brake report at the pre GTG service Toyota always tell the wife that the brakes haveonly X amount left on them. I have wanted to up grade so will source an
    upgrade option soon.
    Troy
    May 2010
    Wodonga, VIC
    303
    One thing you must do after water crossings if you have a winch fitted is give it a good run to heat it up and evaporate the water in it. Leave it a few weeks or more and next time you go to use it you are a good chance it will not work. This has happened to me with a new Warn winch years ago, lesson learnt.
    Prado Polar White 150 GX 3.0 TD Auto. HR TB, ARB delux bar, Hella R2000 lights, Magnum winch, ARB 50mm lift, BFG AT 265/70R17 on 71/2" alloys, Alloy side steps, Rhino sport bars, Tint, UHF, Scangauge, Aux batt (ABR kit), Cargo barrier, 50l water tank, Storage system, Elec brake con. ARB compressor
    Mar 2011
    Melbourne
    3,922
    Good reminder James, I only did it once during the week.
    Senior Member Nema's Avatar
    Mar 2011
    Narre Warren, Vic
    301
    Well I have the new CV in now and the second one is ordered (My road side repairs sort of worked). New rear shock bushes are sitting in the garage ready to go in on Friday and the new mirror I picked up on the way home will also be fitted on Friday but at this stage the amazing glue that Anders used is holding the old mirror together quite well (Nearly temped to leave the broken one there till the glue fails). New front diff oil replaced when the CV went in and I also have a new bump in the rear fuel tank and a puncture in the front bash plate that when straight through the metal from Billy Goats (Slipped off that pointy rock in the pouring rain). Ill try and get the Prado back on the hoist over the next week to see if there is anything else I need to tidy up. I also need to run my winch rope out and wash all my straps that we used heavily on Hernes Spur that lovely day.
    90 series prado with lots of stuff.
  11. #11
    My rear fuel tank guard is knackered after doing Billy Goats on bump stops!!!
    Still waiting on Toyota to get the airline to fix the suspension.
    Front bash plate is missing few bolts too...
  12. #12
    Advanced Member JPH's Avatar
    Aug 2012
    Geelong, Vic
    720
    Quote Originally Posted by Anth120playdo View Post
    Mate I'm surprised you waited this long after being away, sure she would've loved it too!
