  • Originally posted by LowRange View Post
    That looks great.
    I tested the towbar, Prado handled it excellent.
    Very nice setup. Great boat.
    • Originally posted by Ribman View Post
      [ATTACH=CONFIG]24791[/ATTACH][ATTACH=CONFIG]24792[/ATTACH]
      From bird struck damage to LED => spectacular!
      Where do you get those LED conversion kits?
      • Originally posted by thebigo View Post
        I bought myself these last week. Should be here any day now
        Look at this on eBay:
        https://www.ebay.com.au/itm/142161591917
        ARB LED Fog Light Replacement Kit
        11/06 kdj120 gx wide body auto
          Hi Bigo,
          I got mine from this company at Caboolture.
          https://www.gumtree.com.au/s-ad/cabo...ors/1110116105
          Wish the OE ones were this good. Sadly, I now like them more than my headlights!
          Ribman
          • Got her wheel alignment done finally
            then found out the left wheel bearing is buggered another thing to fix on the list
            • Changed the rear brake pads. The caliper bolts were a prick but after the purchase of an impact wrench off they came.
              • Cabin filter
                I took the cabin air filter out and gave it a clean. (It is located behind the glovebox) It had half a dozen leaves and a lot of dust on it. I think there is better flow out the a/c ducts now.
                • Rotated the tyres. Dam heavy buggers or i am just getting old
                  • Originally posted by Graz View Post
                    Either they're heavy or I'm getting old too.
                    • heavy and getting older or at least that's what I'm feeling
                      • Bled the brakes because the pedal is feeling very spongy and going to the floor lately. It's a bit better but still pretty bad. Told it's a bad master cylinder... Now I gotta get a new master cylinder
                        • Changed the first (under car) fuel filter, I replaced the M4 retaining bolt with something longer. Much easier to replace.
                          • Changed out the Injectors, last set only lasted 59,000k and are stuffed ????? don't know why. Have a bit of carbon buildup on them but not leaks blowby etc.
                            Oh well, needed to break my back working under the bonnet i guess
                            Thanks #### for the parts.
                            • Installed new 2nd filter, hopefully these Injectors will last a little longer.
                              gspy4u
                              • Not today but I changed the LHS wheel bearing. It was definitely beyond stuffed.
