  • Originally posted by LowRange View Post
    [ATTACH=CONFIG]25199[/ATTACH]
    Gave the old girl a service, done all fluids diffs, transfer case, gearbox, engine, filters, greased prop shaft. Was going to fit an EGT gauge but the bolt on the exhaust covering the sensor hole is stripped so will continue that tomorrow and fit some new headlight globes.
    Oil pickup screen is all clear, and i got lucky with the hex bolts on the front diff no monkeys had swung off them so they come off fine.
    Bloody hell - I want YOUR shed!
      My garage ceiling is too low or I would have a 2 post in there too.. :/
      • Replaced my left mirror after my awning smashed it and fixed/strengthened the awning. Also adjusted my home made awning brackets so the awning sits lower.
        • Awesome snow run
          • I left mine at the garage to replace with 2" suspension and going to get Terrain Tamer set.
            SelvanD4D
              Envious of your workshop and hoist there Lowrange...
              I have to be content with - trolley jack, axle stands and garage creeper!
              Troy
              Thanks, yes having the hoist makes things so much easier. The shed is purpose built for the hoist with reinforcing beam running under the slab from post to post and the roof height so it can be fully raised. But like all sheds, it could be bigger.
              If you are ever touring through this area and need to make some running repairs, you are welcome to use it.
              Awesome snow run
              How great's that, snow already and a decent amount too. Looking forward to Barrington Tops getting some white stuff falling.
                Against the dirty/rusty chassis that plate certainly pops!
                Not much rust, but too much time in the outback, hardly any time on the bitumen. Red dirt!
                • i have a Grande with an ironman steel bar and winch with no problems at all don't really see what the issue would be
                  • Originally posted by LyndonRW View Post
                    Ok then?!
                    • I picked up mine from the garage with new set 2 " lift Terrain Tamer Heavy duty suspension kit. TGSP120 Shockers and TTCS Coils
                      Very Happy!
                      Regards,
                      Selvan
                      SelvanD4D
                      • Originally posted by SelvanD4D View Post
                        Very Happy!
                        Regards,
                        Selvan
                        http://www.terraintamer.com/images/p...ota/SK001i.pdf
                        Front 555mm max length, even less than my old Bilstein 712's (560mm) Not suitable for a lifted Prado, it will top out.
                        Good luck with it.
                        • I pulled the head off the motor today looking for a busted piston. Didn't find what I was looking for.
                          While it was off I pulled the EGR down and gave it a clean
Name:	EGR Elbow.jpg
                          • Repolished the roof. I did it last week but it went powdery. A mate of mine gave me a tip of when you spread the polish around give it a light mist spray of water then rub the polish. Made a massive difference. Got the marks off and it's now shiney and smooth.
                            • Had my Prado for about a year now, new tyres on yesterday, and a few other things..
                              • Originally posted by TurboD4D View Post
                                [ATTACH=CONFIG]25219[/ATTACH]
                                [ATTACH=CONFIG]25220[/ATTACH]
                                [ATTACH=CONFIG]25221[/ATTACH]
                                looks pretty good in there? :P
