DPF
  • DPF
    Hi I have a 2008 Prado 3.0L Diesel 165000km. I have been searching through various threads but am unable to find the answers to the below
    Does the 2008 Prado have a DPF?
    Just change oil and oil filter used Ryco Z18 is this equivalent to Toyota original filter?
    Used Penrite 5W40 is this oil too thin?
    Is this model Prado D4D prone to injector issues aswell?
    Any help would be appreciated!! Thanks!
    No DPF, that European stuff at this stage.
    Injector issues? Nah, mate. This D4D is bullet proof. OK, I lied. Check out the diesel rattle and injector seal threads. Read it all lest you will find out why it's called D4Detonate.
      I've done a handful of changes using Penrite 5w40 on 2008 as well.
      I a significant change in how the engine sounded and felt after putting the 5W40 in. No problems so far from ~20 000km running 5W40 with 5000k changes.
      Not sure how much the Ryco ones are, the last genuine filter I bought was $28 and I'd much rather a Toyota filter then generic.
      As Bushbasher said, check the other threads and come to your own conclusion. I had my sump pickup cleaned at last service (90k), and it was perhaps 25-30% blocked with crud, and that's with regular oil+filter servicing.
      At the end of the day, as has been said over and over again, regular oil and filter is great, and generally you can't go wrong with doing the change. I only buy Penrite when it's on special. Check between Repco / Supercheap, I've often found that one or the other will be significantly cheaper than the other on special. $75/10L if I recall correctly at my last purchase at Repco.
