Electrical accessories?
  • Electrical accessories?
    My 120 series Prado will be going in to get my light bar connected and to have a few other things added, dual batteries, engel plug and a power panel etc. Can anyone tell me what else is essential or a great accessory to add while it is in the shop?
    Where do I start??? ( all accessories are essential when it comes to a blokes Fourby!
    Depends what your intended use of the vehicle is Benok. An on-board compressor such as the ARB unit is great to have as it's one less thing to pack, is always available, and of course is there ready for when you install that Air Locker that you've always needed!
    Sent from my iPhone thingy
      What is good to do and I should have done this when I first started is to run 7 core trailer wire through the firewall grommet. Then you won't need to keep adding new holes through the grommet every time you want to add another circuit.
        As Craig says, where do you start. Auto Electrician is not my bag. However if your having an engel plug fitted, you get one of these put in the cargo area or something like it: http://www.baintech.com.au/power-pan...ion-panel-vuce and whilst your at it run an Anderson plug to the rear bumper bar, into which you could plug a Charger to maintain your batteries....and later solar panels? Not essential buy hey what's money!
          Thanks for the replies. All great ideas I hadnt even thought about. I will be doing mainly touring so I guess the more gadgets the better!
            I had this done though found that the wire size was not sufficient to run my ARB 47L fridge. Had to then have 6mm2 wiring run separately. Am still deciding how I am going to tidy this up better.
              The trailer wire is meant for switch signals to power relays located in the engine bay that are then connected with the appropriate wire gauge to the accessories that are being run outside the cabin.
                Good point amts. You mean like compressors, driving lights, rearward facing lights, etc.?
