While driving slowly today with both windows down in traffic, I heard a faint squeal... like dry rubber on metal.
I did a bit of Investigating when I got home and found the issue.
I jacked up the front wheel while the car was in neutral (auto) and spun the front wheel.
Right at the joint of where the drive shaft enters the transfer case there is a squeak, like dry rubber on metal.
I head to the Simpson in 4 days time... any help here would be good. If I need to get this fixed, it has to be done in the next day or two.
BTW there is nothing leaking, I gave the joint a quick squirt of silicon spray.
Thanks in advance.
Thanks in advance.
