Hazards work but indicators don't - any ideas?
  • Hazards work but indicators don't - any ideas?
    Hi guys, interesting problem - my indicators have stopped working - but the hazard lights still work - have found the fuse, and as expected it uses the same one (fuse and hazards) - haven't found the relay, but expecting the same result. Any ideas?
    Ivan
    03 1KZ
    08 D4D > Build Up here > [url]http://www.pradopoint.com/showthread.php?18458-Ivan-s-2008-D4D-GXL[/url]
    Canberra
    sorted - IG1 fuse, am sure we checked it and it was fine - and it threw me that hazards were working - in any case, problem solved
    Canberra
      This happened to me on my 90 series, for some strange reason there are separate fuses for the flashers and blinkers. Weird!
      Michael and Kelly
      [SIZE=1]1999 Prado Snowy 3.4L petrol, Ultimate Suspension 50mm lift (2013)[/SIZE][SIZE=1], BFG A/T, bull bar, winch, Twine hot water shower, home made rear drawers, Shippshape car top tent, UHF radio, tablet GPS & Navman GPS (both running OziExplorer)[/SIZE][SIZE=1], Spot 1, solar panel, second battery, inverter, Engel fridge and more[/SIZE]
        Flasher can ?? ......Cheers Steve
          Two different flasher units.
            The IG1 fuse, i second that.
            I had same issue today in my 150 after fiddling with a DIY electrical mod this morning.
            Googled this thread, checked my IG1 (7.5amp located near drivers knee) to find it blown. Replaced, and im back on road.
            Thanks for providing the answer!
              Hi Guys
              I'm having little bit deeper problem. I have just returned from my Cape York adventure and until we reached Melbourne on Wednesday everything was fine. However, yesterday i had a following problems:
              1. Starter motor is not engaging - only lightly click noise on solenoid area and not cranking. after couple of attempt it's starred and same issue comeback this morning.
              2. indicators have stopped working and hazards lights are working
              3. in dashboard Handbrake, ABS and engine symbols are ON.(illuminating - not flashing)
              4. Fan, Mirror control and heaters also not working.
              As per above threads, I have checked IG1 fuse and it's OK.
              Any Ideas please?
              Thanks in advance.
              Selvan
