+30 offset
  • +30 offset
    Hi guys looking at buying some rims for my kakadu,
    It's stock as a rock in the suspension department,
    Will +30 rims fit on? They are 17/9
    Thanks heaps
    Mike
    I think you may struggle beyond +20..
    I just put 17x9 +20's with 285's on them and they go very close to the guard line and just clip the mudflap when turning at low speed..
    we trial fitted +30's with 265's and it was a no go..
      +30 on a Kakadu is illegal. The 9" width will most likely foul on the KDSS components.
        9 inch fits fine
          No. Won't fit (will rub on the KDSS naughty bits) and would be illegal anyway because they reduce track. FJ wheels fit and are legal. I think they are +15 but check the wheel database on here.
            dont want to argue but I am staring out the window right now looking at a Kakadu with 17x9 +20's that fit fine..
            Did you try them on your Kakadu and they not fit?
              The OP's question was about rims with an offset of P30 and that is what I replied to, not your posts. With regards to yours you didn't state it was on a Kakadu and sorry but if they rub even a little bit to me that means they don't fit properly. The FJ rims fit without ant issues.
                Originally posted by Green dog View Post
                9 inch fits fine
                Thats what my wife said!
                  Heya guys, I just bought my 2012 and looking at changing the rims, maybe tyres later, but was going to stick with the 18", though the tyre mob tells me it's a shocking size..
                  I'm just wondering with offsets, is +30 bringing the tyres closer together or further apart?
                  I've been told that trying to for 33" tyres with the standard +25 offset fouls on the upper control arm I think it was..
                  Cheers..
                    +30 brings the wheel closer together.
                    When specifying tyre size, you need to specify more than just 33". The exact size in normal terms is better - 285/70R17, etc.
                      After a bit more reasearch I'm looking at putting a 275/70R17 tyre on (10.8"W x 32.2"H) my 2012 Kakadu..
                      Do you know if will foul on anything..
                      I'm not sure where to go to find tyre dimensions that'd suit..
                        Depends on rims and tyre make
                          • You can't reduce the track on a car (mentioned above).
                          • You can increase your track on a MC type vehicle, like a prado, up to 50mm. (ncop)
                          • Use http://www.willtheyfit.com/ to check the track change (plug in your details and your proposed details).
                          • The wheel size database thread on this forum is a very good source of information. It will help gain an understanding of what you need to know.
                          • My understanding for 17" wheels/tyres is that 285/70/17 is the maximum practical size you can go before you need to start considering large mods.
                          • The standard 17"x7.5 GXL wheel offset is +25. Going a lower offset will widen your track. The maximum offset for a 285 without rubbing is somewhere in the vicinity of +15-+18mm for a 7.5 wide wheel. I am unsure about the kdss gear though.
                          • When going a 8 or 9" wheel, you need to consider the expanded width of the rim relative to the offset, and the track. My latest purchase is 17x8 +10, which is a 21mm track difference per wheel or 42mm in total. 4 more mm per wheel and I'd be breaking the rules.
                            Well I settled on Tuff T05 20x9 rims with 275/55R20 BFG KO2's..
                            I just want to be 100% certain that they'll be ok before ordering it all that it will fit..
                            There's a bloke who has 285/50R20's fitted and they are 0.7" diameter less but 0.4" wider and he seems to not have a problem..
                              This +1.
                              +30 makes it a narrower track = illegal. You need to go < +25 (which is the std 150 series offset).
