Folding mirror module
  • Originally posted by StewyD32 View Post
    Thanks for that Krytox. I was actually looking at that. Was one of the first oces what comes up when searching.
    How long was delivery?
    11 Days
    Then I bought another for a mate.
    10 Days for that one.
    • I ended up buying a unit from https://www.aliexpress.com/item/Car-...311.0.0.g6p5wv
      Went to install it today based on the information that is in this thread but I notice some of the wire colours are different. Hopefully someone here can help decipher the crappy instructions that came with the unit.
      I have found the green and blue lock/unlock wires in the JG3 connector, but the colours on the module are different. I also have a red, pink and orange loose wires in the module that need to be connected. I assume the pink goes to the bigger red wire in the white connector (underneath JG3), but where does the red and orange wires go?
      Some pics of what I got in the box - http://imgur.com/a/hMpg4
      • This is different what i got. No wire goes to mirrors itself. Ask seller for more information cheers
        • Originally posted by jongrant View Post
          I just installed this one https://www.aliexpress.com/item/Inte...f-412eab9783aa no problems using these instructions http://www.pradopoint.com.au/showthr...l=1#post558039.
          Your wiring diagram looks like it is:
          Orange - UNLOCK wire from the folding module goes to that Green wire on the black connector.
          Pink - LOCK wire from the folding module goes to the Blue wire on the black connector.
          Red- Power wire
          [B]Steve[/B]
          • Thanks krypto, that worked alot better!
            • Originally posted by Skprado View Post
              Hi mate here is the link
              http://s.aliexpress.com/BZJz2MZV
              Cheers SK
              So me and a fellow South African order 2 of these units, after making payment the supplier informs that the "interface" plug is not the same for the South African Prado. I find this bizarre seeing that the Prado is not made in SA - I think they are all made in Japan (should be the same vehicle all over the world). Any suggestion what alternative we can use?
              Thanks and kind regards
              Edwin
              • Originally posted by EvWyk View Post
                Edwin
                Have a look at the picture of the plug, it's pretty easy to see.
                [B]Steve[/B]
                • As Krypto said. Remove the mirror switch pretty easy n than check the plug. If its same it will fit Cheers
                  • Originally posted by Krytox View Post
                    Fitted mine last night
                    I bought:
                    https://www.aliexpress.com/item/Inte...608.0.0.1Kut53
                    As DGW (post#117) said very easy to install. Takes about 30 mins.
                    I've Simplified the correct wires to attach the module to: http://i383.photobucket.com/albums/o...psogqhto0p.jpg
                    I hope this helps others!
                    cheers Andrew
                    Thanks mate worked a treat!
                    • Anyone have an issue after fitting the folding module with the left side camera angle all wrong;
                      Mirror camera angle is only lined up correctly when mirror is folded in.
                      • Originally posted by zoneman View Post
                        Not after fitting the module but mine is same as you described one day it decided to change the view. Manual says if something hit on the mirror while 4wd camera angle can change display. Contact toyota. I didnt hit anything. May be player need reset dont know how to do. Tried n removed battery terminal for 2 week was overseas . It reset everything not the headunit. All settings was old. So hopefully someone can help how to reset just headunit. Cheers
                          Thanks skprado for the advice,
                          Its a bit of a strange situation, as the auto folding works like a gem except for messing up the camera angle on the 2010 Kakadu, so proud of my China bought product for $26.00 delivered,
                          So here is the problem, when I disconnect the main plugs back to normal, so isolating the module & new auto fold as such, just like magic left under mirror all lined up
                          correctly again.
                          My thoughts are I might play around with unplugging terminals at different times with mirrors open/closed, ignition off/on etc.
                          If this doesn't work it might have to go in the bin as wife needs side camera for parking,
                          but would be good to auto fold as just read how much a new mirror costs.
                          Cheers Zoneman
                          • Hi zonema, i did tried after reading your post to disconnect the closing module but all the same no change. When you fold the mirrors with switch. Does the screen flick and than change the display. Or its same all the time. Mine flicks than change the display. Cheers Sk
                            • Hello Skprado
                              Mine does the same as yours with the switch only when module disconnected, folds then flicks image, so all normal there.
                              Problem is only with auto box connected.
                              Haven't had a chance to play around again, unless someone else has any ideas.
                              Cheers Zoneman.
                              • Hi all.
                                Has anyone used of the modules from the below suppliers on ebay.
                                (I know aliexpress is cheaper but I want the ease of using PayPal which aliexpress does not have the option.)
                                - virtuecompany4u
                                - sboautoparts
                                - autop-centre
                                Alternatively :
                                If someone has a link to which one they have bought from on aliexpress and was safe and recommend I'll go for it.
                                Any help would be good.
                                StewyD32
