Thanks for that. For some reason that link wouldn't work on my laptop when I looked at it last week, but works on another laptop, so bought one now. Thank you.
Out of interest what was your delivery time?
Has anyone installed this on a MY17 150? I installed it but it is not working. When I flick the fold mirror switch the dash lights turn on to their brightest. Any ideas?
Thanks skprado for the advice,
Its a bit of a strange situation, as the auto folding works like a gem except for messing up the camera angle on the 2010 Kakadu, so proud of my China bought product for $26.00 delivered,
So here is the problem, when I disconnect the main plugs back to normal, so isolating the module & new auto fold as such, just like magic left under mirror all lined up
correctly again.
My thoughts are I might play around with unplugging terminals at different times with mirrors open/closed, ignition off/on etc.
If this doesn't work it might have to go in the bin as wife needs side camera for parking,
but would be good to auto fold as just read how much a new mirror costs.
Cheers Zoneman
Hi Zoneman,
i have a 2012 Kakadu, was just wondering is it only the side camera that plays up, does the front camera still work okay?
As i am looking at getting one of these folding mirror modules, i can live with the left camera not working correctly, but it would be a deal breaker if the front camera doesn't work.
Thanks MacroP !! I did read your earlier post #68 in this thread but thought it was for the updated Prado for some reason. I have had another look and wired mine that way now. Seems to work as it as it should, BUT now when I open the drivers door after unlocking with the fob, the car beeps 10 times and the indicators flash. Anyone else come across that?
I have just tried to install and failed with the same problem.
Even with the module removed it still beeps and flashes 8-10 times when I unlock and then open the door.
I can't seem to find if this was resolved and if so how it was fixed.
Thanks,
S.
I have fitted one of these to my Land Cruiser and it works perfectly as in lock vehicle the mirrors close, unlock vehicle the mirrors open. Problem is when I select multi terrain mode the camaras do not work, if I press the mirror close switch and then release it the camaras work for about 5 secs then something clicks and they go off.
Quick update, have removed this mirror module and not only have my camaras started working but also the flat spot in the engine has gone, so module can go in bin and I will press the button to operate the mirrors.
