Kaymar Rear bar install ???s// Lexus GX460
    Yeah, I have the TJM T13 bar fitted. There is a pic on the 2014 facelift bullbar pics thread. Not sure but I would think the pre facelift bullbar would suit yours the best. Would probably have to get some good photos of the front end with some measurements of some areas, specifically the grill height.
    I should be fitting the rear bar some time next week, just in time for Christmas
    [LEFT]Silver 150 Facelift
      Well, due to one thing or another, it didn't get done before Christmas.
      Have tackled this yesterday after work and finished off today. Looks good and I'm happy, however the instructions for the cut aren't perfect. I had to cut a bit more off my bumper to get it to fit, at least it wasn't the other way.
      Bumper off and tools spread everywhere
      What's left of my poor shiny bumper
      A bracket you have to rivet to the vehicle to hold what's left of the bumper out
      How it sat with the bar first fitted, you can see how the bumper overlaps the bar, which holds the bumper out and looks terrible
      And after my extra trim to the bumper, mud flap fitted and looking good
        One last photo for now, with my helper watching on.....
        Still waiting for my right wheel carrier and the bracket for the door handle, they had to get re painted because the carrier was scratched when I went to pick it up, and the bracket was painted too thinly, you could see the powder coat through the colour.
        I can assure you it was a bitch to get some of the bolts lined up and started, but other than that it wasn't too bad. Make sure you have a mate helping you lift it on and off, this is a bit tricky because it is tight over the chassis.
          Looks good. Can't wait to see it all put together with the last few parts.
          Couple questions about the template:
          What reference points did the template use?
          From your picture it looks like it used the contour line mid way up the side of the bumper (line that runs parallel with ground). This could be tough, since this contour line is significantly different between GX/ Prado.
          Was there a reference point on the wheel well edge?
          This would be the same on GX/ Prado, and if so, I could just straight line it to the flat portion under the barn door...
            The template does line up with the contours on the rear bar, but also does have some measurements in the instructions. There is a measurement along the wheel arch for that end of the cut, I guess it could be straight lined to just below the flat step area. I would cut it longer than needed, then fit the bar. Once the bar is fitted do the final trim to get the level perfect. Will be a bit time consuming, but the results should be perfect.
            I can't wait for the rest of my bits either, gotta wait for the paint shop they use to reopen now........
              I'm looking to make the same mods with my 2011 Lexus. Thanks for the info can't wait to see how it turns out.
