Takes a while to disengage 4wd
  • Takes a while to disengage 4wd
    Hey fellas i dont know its normal but when i disengage 4wd mode it takes a while for the light on thedash to go out, i have to drive for a few hundred meters after moving the knob? Is that an average thing or not? Cheers
    Sometimes happens on mine. Usually goes out within a hundred metres though. Never more than a hundred metres though
      When that happens try find some grass or hard sand to drive on , it's tension in in the syncros
        But it isnt going to cause any problems is it?
          It's known as transfer bind up, the most common way to help it disengage is to move forward and backward about a car length. At least that is always what I have been taught and have seen done quite often. No issues unless it doesn't disengage and you keep driving on it.
          [LEFT]Silver 150 Facelift
            Add to that turn your steering wheel left to right as you go forward and backwards too. I used to work in Isuzu trucks that were a pain to disengage sometimes and that method worked everytime.
              You are disengaging before you reach the bitumen aren't you?
                Yeah i usually disengage as soon as i dont need the 4wd anymore which is before the bitumen.. does it make a difference if im on bitumen or dirt?
                cheers for the replies fellas!
                  The softer the surface you disengage on, the easyer it wil be for the transfer to disengage 4wd, as the wheels will be allowed to slip easyer.
