150 auto transmission oil cooler install - Davies Craig 678 with fan and thermo switch
    Easy to make a new bracket for this. Use the existing bracket but bolt on to the bottom bolt of the aircon cooler, then a piece of 20x3 with a bend and a couple of holes and your done. Just be carful when removing the plastic clip from the end, it breaks easily. If you don't have this pipe supported it could fail from fatigue.
    Rusty.
    hosting image
      There is enough interest for me to order a batch of brackets. It will take about a week.
        Thanks for doing this.
          I'd like 2 lots of brackets please if not too late. How would you like payment?
            I stated you were on a winner.NOW about my Commision !
            2016 ISUZU DMAX TWIN CAB.
              If you are interested in a bracket kit please see this thread.
              http://www.pradopoint.com/showthread...vies-Craig-678
                Reading the install instructions here;
                http://www.daviescraig.com.au/Images...)(20Aug13).pdf
                I get the impression that the "stock" install has the fan constantly running whenever the ignition is on. I wonder how long the fan would last? Maybe another option is to have a dash mounted switch so as it can be activated when required, like when driving slow on soft beach sand, or when scangauge tells you it's needed.
                I aslo note the warning about the fan can only turn in one direction, and the you can reverse it by taking the blade off and turning it around, but the polarity must be set up so as that the fan turns in the direction of the arrow.
                Prado 150 2014 GXL 3.0 TTD - gone after it failed me bad. Now MY16 GXL TTD 200
                  Originally posted by Tin175 View Post
                  The Craig Davies 678 cooler seemed to be a popular choice. It can be had for around $150 which is good value considering it comes with hose and fittings. I bought the DC0698 for $230 which is a 678 with a 8" fan. It came with hose, relays and fittings but no thermo switch. I bought an inline thermo switch for $40. I also needed another metre of 3/8" oil cooler hose and a 3/8" hosetail joiner.
                  I've found the DC698 kit for $194 delivered on eBay - so I ordered that. But I can't work out where to get the hose, joiner or thermo switch from! Any ideas?
                    Super cheap has the switch. Hoses and joiners from Repco
                    Blake
                      Hi Tin, great work. I've sent an email, regards Chris.
                        Ok, got the hose and joiner from Repco. They didn't have the switch in stock.
                        I've looked on the Super Cheap website and can't find the switch is it there? If anyone can find it can they please share the link?
                        On the plus side the brackets turned up today! So now I've got everything except the switch and enough time to install it :-)
                          Is this the switch?
                          http://www.supercheapauto.com.au/onl...ecommendations
                          Blake
                            I bought this one.
                            http://www.ebay.com.au/itm/261368005...84.m1439.l2649
                            Mine leaked a little so make sure you unwind the thermo switch from the body and apply some sealant or thread tape.
                              Just found them. #. Derale 15721 -8AN x -8AN In-Line Fluid Thermostat. #
                              Hi Tin, sent an email yesterday. ( to the wrong adress,whoops ).
                              Just checking it came through ok, today? Thanks heaps, regards Chris.
                              humungusmon
                                I'm pretty sure that's for radiator coolant based on the Davies Craig website and install instructions. I have no idea why they are listing it in the oil cooler section!
