Originally posted by 042FWD
View Post
Rear Underbody water tank for 150 Prado
That looks like a great addition to the Prado.
Do you have plans to sell / share plans or completed product.
John[FONT=Comic Sans MS][SIZE=1]2014 Graphite GXL Prado 150, D4D Auto, Cooper ST Maxx 265/70R17, Full black leather upgrade
ARB Deluxe Bar in Graphite, Warn Zeon 10,000lb winch, Recovery Point, ARB Intensity 21 LED Lights, Safari Snorkel, CKMA12 Compressor, 2" OME Lift, ARB Battery Tray, RedArc SBI12, Icom 440N UHF, 120W solar panel, diff and transfer breather extensionsSIZE][/FONT]
Originally posted by Sungold View PostThat looks like a great addition to the Prado.
John
New lower tap and rear door tap.
I found a tap that I'm happy with now. Departure angle clearances are much better. The tap is chrome plated, quarter turn and lockable.
I also installed pump and faucet combo I got from Whitworths. I was concerned that the pump might not have enough grunt to push the water up the metre or so to get the the door but it worked really well.
It was a bit tricky getting the 10mm hose and all the required wiring through the rubber hose thing between the door and the car. WD40 is you friend and in the end it wasn't too bad.
I also mounted the level meter indicator on the back door near the tap. The flat section in front of the door grip hole almost looked like it was designed for it from the factory.
Packed away when not needed.
The way I plan to use the tank will be to fill it from the lower outlet which has the hose connection on it. I hook it up to the garden hose and it takes a few minutes to fill it. Its full when water starts trickling out of the breathers. Because the pump is a centrifugal pump with not valves the water also comes out the faucet if you don't turn the tap off quick enough. Just need to make sure the door is open when filling or you'll get the boot wet.
I will also make up a length of hose with a connector and a funnel if I need to fill it from somewhere without mains pressure water.
craigm like this!!!
Nice work Tin...
Originally posted by Tin175 View PostI found a tap that I'm happy with now. Departure angle clearances are much better. The tap is chrome plated, quarter turn and lockable.
I will also make up a length of hose with a connector and a funnel if I need to fill it from somewhere without mains pressure water.2004 V6 Grande. BLACK -
I took the car out for a day trip to the Glass house mountains on the weekend to test out the swaybar disconnects and clearance around the water tank.
Tackled some steep rutted climbs, tight washed out tracks and some small bog holes. Don't want to brag too much, but the Prado was easily the most controlled and capable rig on the day. Much less wheel lifting or wheel spin than the others. Traction control as always is very impressive.
Major weaknesses were the side step clearance and departure angle. I dragged the ass over plenty of dirt and mud. I kept on checking the tank everytime I got out expecting the tap to be ripped off. However all was intact and working even though I managed to put a dent in the rear fuel tank guard and a few more scratches on the towbar. I was pretty happy. Also having water to wash off all the mud and dust was a bonus.
As for going into production. Its on my to do list this week to get a costing together to make a small batch. Being 100% stainless steel, cost will be a challenge, but I'm looking into ways to make it cost effective. I'll have proposal together in the next week or so and see how much interest there is.
I'm off to Moreton Island over easter so will be glad to have the tank and it will be another chance to do a bit more hands on testing.
Tin...I love your work, your obviously a man of great detail. My 120 Prado spends much of it's life in the garage. If you would like a project to trail fit one to a 120 series..PM me and I should be able to work something out for a week or two. Time limited offer though as my partner is nearish to getting her licence..so I loose the sedan!
I recently bought some 20l Willow plastic jerries, strapped them to my lifestyle rack and used the 'old' garden sprinkler jet gun as a tap (with drinking grade hose). Works great, this just looks a lot neater and practical.Last edited by macaroon1; 18-03-2015, 09:13 PM.[SIZE=1]03 TD 120 Grande, L&R weathershields, f&r deflectors, Sov bar Amts rad b.pl, TJM front B.P, Uniden UH7760NB Kaymar LED worklight, ARB 47l, lifestyle rack & Milford C. Barrier, 9500llb Superwinch, IPF 900SR spots, T. Dog 40mm adj shocks/struts, coils, airbagman OA6011 airbags, 2.75" Beaudesert exhaust, 300w inverter, 1L Catch can,outback rec points, R.R awning, dual batteries redarc SBI12 Cooper LT A/T3's 265/65, Safari snorkel, Hilux jets, Brains TG150, Leigh's booster diode [/SIZE]
The 120 doesn't have as much room as the 150. There is a plastic water tank made by Longranger.
http://thelongranger.com.au/pradolongrangefueltank.html
It only holds 21 litres. A stainless tank made to fit that space would have even less capacity. So unfortunately, its really a good candidate for a stainless steel water tank.
I know once I show the boss your setup Tin she's gonna want a tap on the back door. Any way you can tell us the parts involved so I can try and fit it to my tank?
Cheers mate. Awesome work again
Sent from my iPad using TapatalkCheers
Blake
Originally posted by craigm View PostMeh... Like this one better
