Help needed - wiring harness differences with 1998 5vz fe engine compared to a 2002 5vz fe
  • Help needed - wiring harness differences with 1998 5vz fe engine compared to a 2002 5vz fe
    Hi Guys
    I am needing some help with an engine swap. I have a 1998 90 series Prado with a 5vz-fe v6 engine which has blown and I just purchased a 5vz-fe engine from a 2002 95 series. The issue is that there are a number of differences with;
    1) the ECU harness connectors are different
    2) there are three connctors on the ECU with my 1998 model from the engine harness but only two on the new 2002
    3) there are vacuum lines running from the power steering pump to the inlet on the 1998 engine but no stem for it on inlet on the new 2002 engine.
    4) the 2002 engine harness appears to have different wiring connectors to the 1998 engine harness
    I was wondering if anyone knew anything about the differences between the 1998 and 2002 5vz fe engines and what modifications I will need to make to successfully fit this 2002 engine in place of the 1998 5vz-fe engine?
    Is it just a matter of changing the ECU to fit the new engine or can I just use the 1998 enging harness and put on the 2002 engine?
    You help would be greatly appreciated.
    ATDA
    Can only use your old harness
    Airflow meter is different
    Immobizer is internal on the 02s
    You could make it work but too much effort
    Old harness will go striaght on
    Vacume line on the ps pump just leave them off
      Thanks Scott,
      Sorry just need to clarify... so the old harness should just fit straight on the 02 engine and all connectors will fit straight on to everything, all except the air flow meter?
      So just need to modify air flow meter conection?
      Thanks mate very much appreciated
        hi Atda I have a factory service manual with all updates and wiring diagrams on cd if you want a copy
        cheers
        2018 GXL 2.8 1GD,
          Yep
          Your old airflow will stay with the old harness so no need for modifying there
          all the plugs should be in the same spot but you may possibly come across differnt ones just change to the old s
          Sensor if that happens
            Originally posted by scottkz View Post
            Yep
            Thanks for your help mate, very much appreciated
              Hi Brissy, thanks for the offer but I have one of those.
              Thanks for the help though
                hi i know this is old thread but did you succeed in the transplant in doing the same???
