Exhaust system for 90 series 3.4ltr
  • #46
    Pics and clips or it didn't happen lol
    • #47
      Does it bolt up to extractors?
      • #48
        As previously stated, I get it Monday, and they will be bolted to pacemaker extractors
        • #49
          sweet, how much were your PM extractors?
          • #50
            finally here it is
ID:	652782Click image for larger version
ID:	652783Click image for larger version
            fitted it today, all went well, every flange lined up perfect,
            oceanracer
            Moderated member
            • #51
ID:	652817Click image for larger version
ID:	652814Click image for larger version
ID:	652815Click image for larger version
              oceanracer
              Moderated member
              • #52
                Looks the goods! Whats the graph on the butt dyno showing lol
                • #53
                  do you have one I can use..lol??
                  • #54
                    http://www.pradopoint.com/showthread...d-install-tips
                    Just to add to this thread, I didnt remove anything mine is a manual, I did remove all the studs and nuts and replaced them all, I did pre loosen and anti seize them, only used a deep 14mm socket no extensions and a 14 mm rachet spanner. Extractors and Y piece fitted in under 3 hrs and the rest of the exhaust in another hr and a half, had to Jack the rear up a few inchs to get the tail piece over the diff, all wheels were left on.
                    oceanracer
                    Moderated member
                    • #55
                      So far I've gone 80ks further from the main tank.
                      It did 970ks on 120 lts of fuel, no trip ks just going to work, I'm happy with that.12.7 Lts per 100ks
                      oceanracer
                      Moderated member
                      • #56
                        Just after an update Oceanracer thinking of king brown system for myself, did it improve mid to low torque at allI can’t find any other info on the web about it bar yours
                        • #57
                          Getting the Pacemaker Headers with King Brown exhaust system fitted next week. Opted for ceramic coating on the headers and Y pipe. Gives them a longer life.
                          I carry around approx 420kg in the back packed double stacked drawer system. Getting 16ltr/100km consistently. Towing trailer at times 1.5t. We’ll see if this system makes any noticeable difference.
                          • #58
                            That's a sexy looking exhaust... maybe next year 12.7l/100km is very good going for the 5VZ-FE. Am in the process of running down one of my tanks so I can measure this for myself.
                            • #59
ID:	748727Click image for larger version
ID:	748728Click image for larger version
ID:	748729Click image for larger version
ID:	748730Click image for larger version
                              All I can say is that after driving around 120km today, why did I not have this system fitted years ago. Runs noticeably cooler, holds a gear longer uphill with more grunt.
                              Pull the T bar back and step on it takes out a wrinkle or two. There is a better exhaust note compared to the hissing sound made previously with the old exhaust.
                              Ceramic coating adds a nice touch to it as well as adding longevity. Costs more though. If you are thinking about installing this system you won’t be disappointed.
                              When it’s daylight I’ll put up some photo’s.
                              Jim
                              bigjimg
                              • #60
                                Here’s few more. Click image for larger version
ID:	748733Click image for larger version
ID:	748734Click image for larger version
ID:	748735Click image for larger version
ID:	748736Click image for larger version
