Programming a spare key, new owner
    No, the ebay keys and remote with transponder for about $40 should work, i seem to be the only one that has had problems programming it. Auto locksmiths also sell and program keys.
      Originally posted by scales82 View Post
      Well the pdf was too big to attach (grr) so I am typing out the instructions for anyone who needs it....
      Note: You MUST buy a key that has a matched code printed on the remote. Open up your key and take out the small rectangular remote transponder and it is printed on it, mine was 50171. Your new spare key must match it... eBay sellers do mention what code they are, if they are not telling you... dont buy from them!!
      You need a master key for this procedure
      What is a master key? ANY working key with a remote in it. Including copies... I had 1 key with remote, now I have 3, each time copying a different key... (copy of a copy)
      IMMOBILISER PROGRAMMING (make car recognise key, so you can start the engine)
      1. Close drivers door
      2. After 10 seconds, insert an already registered key into the ignition. The security indicator should now be turned off.
      **you have 3 seconds to begin step 3.
      3. Remove and insert the already registered key 4 times in 10 seconds.
      4. Open and close drivers door 6 times within 20 seconds.
      5. Remove the already registered key.
      6. Within 10 seconds, insert the new key to be registered ( security indicator should be flashing again), and leave it for 60 seconds in the ignition, the security indicator should stop flashing.
      7. The new key is now registered to the car
      REMOTE PROGRAMMING INSTRUCTIONS (For the buttons on your key to unlock the doors)
      1. Drivers door open and key removed from ignition switch
      2. Insert key into ignition swithc, then remove it TWICE
      3. Within 40 seconds, close and open drivers door TWICE
      4. Insert key into ignition switch, then remove it
      5. Within 40 seconds, Close and open drivers door TWICE
      6. Close drivers door
      7. Insert key into ignition
      8. Switch ignition "ON" for 2 seconds, then "OFF"
      9. Remove key
      10. Computer should now lock and unlock vehicle to indicate you are in programming mode
      11. Carry out the following within 20 seconds: Simultaneously press and hold lock and unlock buttons until the light on the key remote flashes once
      12. Press and hold lock button until light on remote flashes twice.
      13. System should now lock and unlock vehicle
      NOTE: If system locks and unlocks vehicle twice, programming has not been successful. Vehicle is STILL in programming mode, so repeat the button procedure from step 11
      14. To exit programming mode after key has been programmed, open drivers door.
      DONE!
      Hope this helps someone, it sure helped me. I now have 2 standard keys and 1 'flip-out' key.
      Curious to know whether the remote central locking programming would work with a master key which does not have a remote in it?
      My master key does not have a remote in it and that's the only key i got.
      Thank you.
        Thank you.
        Originally posted by Kakaboy View Post
        I only have a black key and no remote. Do I have to go to Toyota to get a remote sorted out
        Assuming you have a black master key and not a grey sub/valet key, it's pretty quick for an auto locksmith to supply a replacement key with a (hopefully) working remote.
        I went down this path on my 120 series that came with only one functioning master key. The guy I used cloned the RFID immobiliser code from my working key and programmed the new remote for central locking.
        As much as I wanted to go down the eBay path and register a new new key in the immobiliser to save some $$, I didn't know how many different RFID codes had already been registered in it over the years, considering it's a 2003 model with 4 previous owners. Apparently there is a limit of how many different keys can be registered before you have to start dicking around with getting someone with the right tools to erase the stored codes.
        Apart from the colour of the key head, you can tell it's a functioning master key because the immobiliser light on the dash goes out straight away when you put in the key. With a grey sub/valet key the immobiliser light stays on for a few seconds when you put in the key, plus it won't work in the glovebox lock, whereas the master key will.
        The locksmith I used supplied a non-standard flip out remote key that you see on newer vehicles. It seems much stronger than the weaker standard remote key shells.
        Hope this helps.
          Hi all,
          Just thought I would add a note for anyone like myself who decided to "upgrade" their key to the newer style flip keys after the old style kept breaking (for Prado 120).
          I got a new style Toyota flip key for my Prado which i bought off eBay, and the programming for the keyless remote part was slightly different for me. It also doesn't have the little red light on it which may be a bit confusing if you are trying to follow the old instructions posted above.
          When you get to step 11 & 12 (after the car is in programming mode) the sequence that worked for myself was.
          A: Simultaneously press and hold lock and unlock buttons for approx 1 sec.
          B: Let go for approx 1 sec
          C: Simultaneously press and hold lock and unlock buttons again for approx 1 sec. (Same as A).
          Car should then lock and unlock ONCE to show programming successful. As above, if it locks and unlocks twice it did not work.
          Not sure if this is the same for the new key style across the board, but you can always just keep trying different combinations until it works (what i did).
          Note that the car will do the lock-unlock thing twice the moment it detects a wrong entry (So if it does it on the first button press, you can assume that is wrong, if it does it on the second button press, you can assume the first one is correct but the second is wrong).
          Hope this helped someone. Thanks all.
            Help please . Went out start Prado , keys wouldn't unlock it so opened it manually , jumped in tried to start it and had had nothing , no lights on dash . Wasn't able to unlock or lock using key . Can someone advise how I can possible fix this please
