Results 1 to 9 of 9
  1. #1
    Avid PP Poster! Spilsy's Avatar
    Join Date
    Dec 2013
    Location
    Benalla, Victoria
    Posts
    1,197
    GXL Rear Seat Removal How To - With Photos
    This weekend marked the time in my life when the rear seats of my GXL had to go. After much googling I found the instruction manual everyone else uses:
    http://www.pradopoint.com/showthread...t-modification
    I thought I'd put up a bit of a step-by step with photos to make life easier for others in the future. This will take a few posts as there's many photos and I can only have 5 per post.
    Remove the tie down points. A 10mm socket gets the bolts out.
    Lift out the fold up floor. This is held in with plastic clips that require a little force to remove.
    With the fold up floor out, it is possible to lift out the left and right wing panels. These are also held in place with plastic clips, a gentle lever up gets them out pretty easily.
    Left:
    Left Panel Removed:
    Right:
    Right Panel Removed:
    Spilsy - Today is the tomorrow you were shitting yourself about yesterday - Billy Thorpe
    2013 Turbo Diesel GXL
  2. #2
    Join Date
    Dec 2013
    Location
    Benalla, Victoria
    Posts
    1,197
    The next step was to remove the rear kick panel thing. This is held in place with 3 bolts. A 10mm socket is required again. I failed to get a photo for this as I was busy struggling with the clips holding the panel in place. It requires a bit of force to get out.
    This is from the manual and shows the extent of the task:
    Across the seats is a metal plate, held in with 2 more bolts, guess what, a 10mm socket gets these out too.
    On the left and right there are 2 more metal bracket things with another 2 bolts. I'm sure you've worked out which socket is needed.
    Left Bracket Removed:
    Right Bracket Removed:
    We are now on the home stretch - one more post should cover it!
  3. #3
    Join Date
    Dec 2013
    Location
    Benalla, Victoria
    Posts
    1,197
    Now that all the brackets are out, its time to finally remove the seats.
    To do this, you will need to lift up/out the seat bases (as you would do setting up the seats). This will reveal the bolts (a 14mm socket here, not a 10mm) holding the backs of the seats in place.
    Now, coming in from the rear doors, flick open the little tabs to reveal the final bolts for each of the seats.
    Guess what, the seats are now ready to be removed. Remember that these weigh about 20kg each, so be careful with the lifting!
    With the seats removed, go nuts. Me, I'm putting in a new set of drawers...here's the starting body work:
    IMG_0601.jpg.
    I hope you can find this helpful. I know I struggled very slightly with the manual...
  4. #4
    Join Date
    Feb 2015
    Location
    Melbourne
    Posts
    223
    Thanks for posting Spilsy, very helpful for those of us who plan on doing drawers.
    2010 150 gxl D4D with ARB delux bar, towbar! Custom DIY drawers, rhino HD bars, 2" Dobinsons, platform rack, IPF lights and BFG AT2 and extras
  5. #5
    Join Date
    Dec 2013
    Location
    Benalla, Victoria
    Posts
    1,197
    As a follow up - The cabin noise increases without the seats. There's no sound insulation in the rear floor pan. Even with my new drawers, the noise has increased. I will be installing some acoustic foam beneath the drawers when I can get myself to clark rubber.
  6. #6
    Join Date
    May 2016
    Location
    Victoria
    Posts
    31
    rear seats
    Great post , just easier with pics and when someone has done it, I like easy. Thanks.
  7. #7
    Join Date
    May 2009
    Location
    Perth, Northern Suburbs
    Posts
    335
    Planning on doing this over the coming weekend. What have people used under their drawers for sound deadening?
  8. #8
    Member The Alberto's Avatar
    Join Date
    Sep 2012
    Location
    Rockhampton, CQ
    Posts
    170
    Excellent post, thanks for sharing, might just be the kick I need to get mine out finally. TBH I thought this was a much bigger job.
    My Build Up
    A Truly Happy person is one who can enjoy the scenery whilst on a detour!!!
  9. #9
    Join Date
    Nov 2015
    Location
    Sydney
    Posts
    82
    Thank you Spilsy. Removed mine on the weekend. Got some Drifta drawers ordered and your instructions are step one in the process.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
