Daxamus' 2003 GXL Build
  • Daxamus' 2003 GXL Build
    So it had a fair bit already done to it, today was install the rear false floor and fridge slide, wire up the momentary switch and in-cab led and bolt on the high lift jack and shovel holder mounts. Got a few pics from the past couple of days for the rear floor build.
    2003 1kz-te, mud-terrain, winch bar, winch, hayman reece, roof cage, spotlights, light bar, reverse led lights, GME TX3100, Wind Booster, dual batteries, side awning, snorkel and soon to come a 2" lift.
    nearly finished
    so i pre bolted the fridge slide to the finished false floor using washers front and back. I cut a small notch out of the carpet to expose the bolt holes as only the ti-down point end has a notch in the carpet - the bolt is normally hidden. I used 50mm high tensile m6 bolts as replacement and then instead of using washers fitted the original factory ti-down points back in through the false floor. Worked well. To get the bolts accurately i put the longer ones in partially and sat the un-carpeted floor on the bolts then used a block of wood and hammer to indent the underside of the ply board for drilling. For the m6 bolts i used a 8mm drill bit and that gave me enough flexibility and room to bolt in the floor once carpeted without any issues.
      final bit install fridge
      Floor was a nice fit with the seats down, fridge installed using the standard engel tie down points, large carabenas, swivels and a rated d-shackle, seems to work well and gives me flexibility. No power as yet to rear of car other than the factory plug. Nice bit of room behind fridge for water or mounting the tyre pump? enough room at front of fridge without being too close. Its really strong in fully opened position. Very happy with the fit and how it all came together.
        Awesome job! Well done...
          Nice work with getting ready for the GTG.
            Thanks guys, yep getting ready and really looking forward to it, got most of my bits just need the time to install them now!
