Water tank - Prado 150 with OEM towbar, Stainless Steel 30L
  • Water tank - Prado 150 with OEM towbar, Stainless Steel 30L
    ITEM: Underbody water tank for Prado 150 with standard towbar
    CONDITION: Brand new
    REASON FOR SELLING: Water storage solution for touring. A few members have asked me to price up a small batch.
    PRICE AND PRICE CONDITIONS: $540 + Postage (Postage to be confirmed. Should be around $30 to metro areas)
    EXTRA INFO: Also refer to this thread http://www.pradopoint.com/showthread...-for-150-Prado
    Tank will be made from 1.6mm thick 304 stainless
    Comes with 1x Stainless 1/2" quarter turn tap for filling and draining
    Two breathers, one on each end to ensure you can fill up even if your on a bit of an angle. Also helps water flow out.
    Will have clear tube on the side of tank to check level.
    Price is based on a batch of 5. Please register your interest and I will increase if needed. If you would like to weld it up yourself I can supply the parts for $290 or $220 for just the stainless sheet pressings.
    Ordering info:
    Send an email to tinhua.tnn at gmail dot com
    Subject: PP username 150 Tank State Postcode (eg Tin175 150 tank QLD 4300)
    PICTURES:
    Email sent. Count me in!
    Tiny
      Just a suggestion Tin, you might want to list the capacity of the tank and a link to the original design thread in the specs above.
        Tank will be pretty much the same as the one in this thread.
        It will have a 30 Litre capacity and can be installed without removing the towbar or bumper.
        The electric water guage costs around $100 for the sender and guage. You will need to drill your own hole to accomodate this.
        This tank is designed to be filled from the outlet in the bottom. It is very easy to do with a garden hose. If filling in the field from an un-pressurized source you will require a length of hose and a funnel.
          I'm in, email sent
            Hey mate, how solid is the gauge on the side of the tank? It won't get smashed if a small rock comes up and touches it? I'll send you an email now.
            [url="http://www.pradopoint.com/showthread.php?31511-Jono-s-MY14-GXL"]My Rig Build Up[/url]
              Gauge tube will be on the front facing side of the tank and will sort of sit in behind the rear fuel tank. The gauge tube will be 6mm clear PU air hose and is pretty tough.
                Good to know mate, I've sent you another email.
                  Tanks have been welded and just gathering the rest of the bits and pieces and fasteners.
                  Picture showing the water gauge and breather connections.
                    Looks good. I'll have to teach the kids how to crawl under and tell me what the level is.
                      Email sent - very keen
                        Email sent!
                          Looks ideal. Keeps the water outside. I've sent you an email to see it they're still available.
                          Cheers Bill
                            Looks awesome. I've missed the boat I'd say but would you be interested in making up another one?
                              Email sent, keen on 1. Email resent.
                              2015 Silver Pearl Prado GXL
