Feedback regarding installation of Cruise Control_Prado (TRJ150L-GKPEKV) 2011
  • Feedback regarding installation of Cruise Control_Prado (TRJ150L-GKPEKV) 2011
    Hi guys
    I am new to Prado (recently shifted from Ford to Toyota).
    I am planning to install Cruise Control Kit for my Prado (As per attached pictures)
Name:	Cruise Control.jpg
    I just want to know that this is the only step needed to complete the installation or it will require Cruise Control option to be enabled by using some software through laptop?
    Awaiting valuable feedback.
    Thanks in advance.
    Guys Please respond...
      Hi it is a bit hard to tell from the information you have provided. For example if your vehicle has a manual transmission you will also need an additional switch for the clutch that disables cruise. The ECM may need a re flash. What I can tell you is that I successfully installed cruise on our 2012 yaris it was just plug and play with the parts you pictured above. However on our 2015 Mazda 2 Mazda can't even do a re flash to make it work when I installed cruise from a higher model grade into our Neo. So being a Toyota depending on the year build you have a good chance of it just being a simple plug and play as you are hoping.
      2016 200 VX TTD Pearl White
        I have install it as a Plug n Play solution, however after finishing installation, it comes that its not working, no response.
        Do it need to activate or ECU programming?
        Any idea which programming tool will work?
        I have VCM-II available with me
          Does the dash light cruise illuminate when you switch it on? If not I would suspect you have to tell the ECU it is there!!
            no light came when switch on Cruise
              The ECU needs to be told the cruise module is there then! It is not plug and play by the sound of it!
                Where i can find the connector? Its located inside vehicle?
                  Sounds like you need to programme the ECU using Techstream provided that this is a Toyota kit and not a knock off. Were there any instructions with it?
                    I m trying to do the same.
                    Facing the issue that techstream is unable to communicate with VCM-II.
                    Any possible reasons?
                      Now VCM-II and Techstream are communicating with the vehicle, do some customization as follows:
                      1. Power Windows Up & down using the key buttons.
                      However i do not found cruise control options to make it enable / activate?
                      Can some expert guide on it
                        How to reprogram ECU for Cruise Control Activation? any idea folks
                          Hi Im on the same, which one do you have? mine is 2012 2.7 petrol auto (same as yours), from what I found on a russian forum, all 3.0 turbo diesel, 4.0 petrol and 2.7 right hand has the firmware to make it work, 2.7 left hand only works from 2014. Also you need to connect the spiral cable to ecm. Somone there change the ecm to 2014 one and it worked for him, Im plannig to do the same.
                          This is the post, of course google translation isnt perfect, as far as I understand, they figured it out that previous years models could work, but the ecm need to activate that option by techstream, if you find more info please send it to me
                          https://translate.google.com/transla...lub.su%2Fforum
                            I have 2.7L, Petrol, Auto LHD
                              When you use techstream it detects the year of the car or you can select manually the year? If its posible, try to run as 2014 model to see if the cruise control menu appears. If doesnt, then the only option is to install a 2014 restyle ecm. I've heard that the key must be register.
