EGR blank off 1KD-FTV
    Originally posted by ttmx83 View Post
    Yeah, I'm pretty sure it was coming out dirty because I changed to Ultimate. The oil pickup was silver and shiny with no junk on it, from what I could see through the plug hole with my eyes covered in dripping oil....
    Might change to 10W-40 permanently next oil change.
    I really want to completely block off this damn EGR system....
    Cheers Brad
    So good oils, have good cleaners, so they get dirty quicker. If the pickup is shiny that's a good sign.
    Let it drain for longer dufus!
    Yeah 10w 40 :-)
    Originally posted by rorza View Post
    ####, do you think you could point me in the direction of a step by step 'How To' (directed towards the layman with no mechanical knowledge) for cleaning the EGR and installing the blank plate?
    Once you remove the elbow how do you clean the end that is attached to the motor? Spray with degreaser or another product and wipe away with a rag or is there a better method? What happens to the soot if it is accidentally forced into the engine during cleaning and is it detrimental?
    It's a prick of a job to do it right, not the sort of DIY you want.
    I'd rather teach you other things to do.
    To clean manifold, very carefully usually lots of rags, carby cleaner, spray rag only. Can't let it be forced or dropped into plenum.
    All depends in its condition.
    Call me & I will try & explain it.
      G'day ####,
      My EGR is blanked off between the Inlet manifold and throttle body i think?, or erg cooler, i can't remember! on my 120 series 1kd.It has 2 10mm bolts and i had to drill a 7-8mm hole in it to stop throwing codes. Is this the best place for the blank or is it better between the head and egr?. Also have you done any EGR blanking&cleaning on a 200 series V8 diesel?, Old man has one but can't find much info on the cleaning of EGR on them.
      Thanks mate
      Aaron
      2016 1GD GXL 6 speed auto, ARB colour coded summit bar, LED driving lights, duel batteries, BF Goodrich tyres, window tint.
        Ok, first drive to work after Mr restriction plate showed 9.8L/100km on the scangauge, previous average was 10.6L/100km. Pretty damn happy with that and the car is so much smoother and has more power. Happy dance!
        Cheers Brad
        [B]2010 GX ,D4D, 6 Speed Manual.[/B] 17x7.5'' +15 FJ Cruiser alloys, 265/70/17 Cooper ST MAXX, ARB bar, Tigerz11 winch, 2'' Dobbinsons lift, Superior front swaybar spacers, extended rear swaybar links, dual batteries, 65L Waeco, custom rear storage, cargo barrier, Fuel Manager pre-filter, breathers, UHF, Narva driving lights.
          Originally posted by azzss View Post
          G'day ####,
          Thanks mate
          Aaron
          Between the head & egr cooler is the goods.
          Up that end can cause unwanted issues & it won't be near as effective.
          Im only on 1kd, way too many of these engines, with some big problems someone has to find good solutions for & repair.
          The 200 is much the same issues, sorry I'm not more help.
            Cheers Brad
            Now he believes..........
            But not more power, it will be more responsive first quarter throttle.
            Is that what you mean?
              Yup, i can go up a gear earlier in the rev range now but it also sings all the way towards redline.
                No, thats great info thanks mate, i will change it between the head and egr with a 7mm hole. Am going to do my brothers 1kd hilux at the same time
                Thanks ####
                  Still getting fuel economy in the low 10's rather than 10.5 - 11.0 before fitting the restrictor plate.
                  Cheers Brad
                    A job today, before:
                    After:
                      I've fitted a home made egr restrictior plate to my EU spec Landcruiser 120 D4D. I've seen people here complain it's a difficult job, now I'm paranoid as it took under an hour including making the plate up from a stainless offcut.
                      I fitted a plate with 45mm between the bolt holes and a 7mm bleed hole in the centre, cutting the corners off so I wouldn't have to remove the egr cooler, just loosen it and slide it in between the egr cooler and the head.
                      The injectors were replaced and intake cleaned when I bought it 6,000km ago. So I'm trying to save myself future hassle.
                      Mick
                        I’ve just done the blanking plate on my Hilux and initially I drilled a 5.5mm hole.
                        After putting it all back together and firing her up I saw the engine light on.
                        When I headed out the gate and put my boot down it said “ you want me to what?”
                        The dreaded limp mode. BUGGER!!
                        Back home, opened her all up again and honed it out to 6mm, no problem.
                        The backside dyno felt a difference straight away.
                        Its a real quick job once you’ve nutted out what needs undoing and what doesn’t.
                        Thanks for all the tips on here lads.
                        I might not have tried it otherwise.
