Dual Battery Volt Meter
    Awesome, thanks for the post just ordered mine as well.
    Originally posted by AK7 View Post
    I'd like to be able to use it on-demand, hence putting a switch in and not using an existing relay.
    That is what I was thinking AK7, flick the switch and it is either ON or OFF, don't have to worry about switching the car to ACC.
      You can use the code "$10forpp" to receive a $10 discount on this item. bit late for all those who have already purchased.
        Turbo that coupon code has expired
        Graphite 2013 "Altitude" with an expanding wishlist.
          just PM him and ask for a PP Discount. That's what I did he gave me the code and told me to put it up on PP
            also one for 120, I see..
            http://www.solidkit.com.au/product/p...it-volt-meter/
            Steve
            2007 Prado 120 D4D 6 spd, 25/40cm lift ARB OME, snorkel, Brown Davis sump guard, Pirelli ATRs (Road), Cooper ST maxx (off Road), ARB lockers & compressor, Overkill rock sliders, dual D27F Optima Yelowtops, Ctek D250, 130A alternator, breathers, GME TX3440, Yaesu FT-857D, Buscomm Highlander 8 multitap or ATAS antenna, ARB Fridge. (VK2FSVN)
              After a bit of thought, I decided that I'd really only ever want to use this if my fridge was running, so I slapped another relay onto the fridge switch and wired that relay so that the volt meter only comes on when I've got the fridge power on Pretty happy with the result and now it leaves that last blank for when I relocate the compressor switch
ID:	652548 Click image for larger version
              It's also worth noting that these volt meters aren't terribly accurate. Fluke meter said they were 13.0V. It's only ±5% variation, but worth bearing in mind. Good enough for a rough guide
                I think the PP discount code "$10forpp" has been reactivated for both the 150 and the 120 models.
                  Got to say I'm a little disappointed after installing this , with both wires hooked up to the same battery for test purposes one display is showing 0.2 volts above and the other 0.2 below what the multi meter shows.
                    The design spec is a tolerance of + or - .2 volts. Unfortunately you seem to have either end of the scale in the one meter (one meter is two separate volt meters). Realistically this is less than 1.7% variation (.2 / 12 *100) but it just so happens the importance of the 12 - 14.5v range for us makes the impact greater.
                    If you are not happy, by all means send it back for a replacement or refund. That's all part of the service.
                    cheers Peter.
                      I've learned that the AC in the Prado sucks 0.5v from the electrical system while it is running - i.e. under normal engine idle, voltage is usually 14.0, when the AC is running, the voltage is between 13 and 13.5v.
                      Spilsy
                        Great Thread. I have just ordered mine and it will do the job nicely (also orders a twin usb charger to slot into one of the switch blanks as well) . I will be hooking up to a relay so it only on when I start up.
                          Hi Peter
                          Tried the code with no joy.
                          Trying to buy voltmeter and usb for 120.
                          2005 V6 VX Pearl White with more and more extras thanks to PP
                            Originally posted by Cookie120 View Post
                            Hi Peter
                            The USB is cheaper on Ebay $25 delivered from same guy
                            http://www.ebay.com.au/itm/Dual-USB-...kAAOSwPcVVuadQ
                              Thanks Turbo
                                Coupon has been reactivated. "$10forPP" is for $10 off a dual volt meter.
