Biggest tyre to fit under factory spare wheel cover?
  • #91
    If I get MT MTZ P3 265/70R/17 and leave it deflated will it fit under the factory spare wheel cover of a 2017 150 Prado? I carry a compressor full time, cheers.
    • #92
      Your biggest issue is rim offset
      • #93
        My first post on Pradopoint! For those still interested I have fitted BFG KO2 265/70R/17. no problems. Tyre can just fit inside the spare wheel case at the rear. So no problems! I also fitted Black Rhino Warlord rims. Offset is perfectly flush with the body of the Prado. Gives an excellent look, and honestly, it gets lots of stares! working on building it up. Have my quote from TJM, just over 10K.
        • #94
          What is the offset of those wheels?
          • #95
            Will get back to you. have asked the supplier.
            • #96
              Official answer from supplier is +12 J. Not sure what the J is.
              • #97
                Good fit!
                • #98
                  No problems with getting spare cover over Cooper 265/65/R18 AT3 LT on 2019 Kakadu with factory rims.
                  • #99
                    Hi guys... Just reading up on the back cover situation with upgraded tyres..I just wanted to check if these sizes that people managed to fit is across the board with all the 150s including the current shape?
                    thanks
                    • Just fit a 265/70R17 Bridgestone Dueler M/T 674 on FJ Cruiser rims under the cover.
                      • Will a 285/70/17 on fj cruiser wheel fit on the factory rear barn door carrier?
                        • I got BFG KO2 265/70r17 installed today.
                          The installers put the wheel cover back on. It fits firmly and there is a small (5mm) gap around the bottom right.
                          I'll probably take it off and lower the pressure and see if it fits better.
                          • i just had Pirelli Scorpion All Terrain Plus tyres fitted in 265/70R17 and to my great surprise the spare wheel cover fitted. Oh yes, tight for sure, but not at all impossible and that was with the spare inflated to 36 psi.
                            • 265/70 falken wildpeak at3w, cover doesn’t fit
                              • 265/70/17 LT 121S Yokohama A/T GO15 cover will not fit and need the bracket spaced out by 3mm or more to prevent rubbing.
                                Fitted these to a set of 2018 GXL rims for touring and am impressed by how quiet they are, no difference in noise compared to the standard 18" Goodyears. They have excellent grip as well as I ran them on a recent trip out and around Innamincka. Not the most agressive tread around but for outback touring and sand work I find them excellent.
                                Lee
