Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 133 to 144 of 146
  1. #133
    Airbag mans are in and pumped up to manufacturers maximum rated operating range.
    Running 285s and there looking small now ! Lol
    I've raised the front a little more, its sitting level... I do want some rake though. Either have to go 15mm higher on rear or 15mm lower on front... I'll have a play with rear first but might make the ride to firm...
    I've installed a diff drop kit to... was just the cheapy but now looking at buying the rear diff arm to do properly...
    Just need unichip to get the turbo injector kit together.... although with the bigger tyres and all the added weight it still smashes stock prados... drinking 13.5l combined driving..
    Photos below are on normal height... raise height gives 20mm more in rear and looks shhmick... wish it would just run on high all time... anyone know how to beat the Speedo sensor for the 55km hr safety ??
    Sent from my SM-G935F using Tapatalk
  2. #134
    Out of control poster! mjrandom's Avatar
    Join Date
    Jan 2008
    Location
    Samford
    Posts
    6,019
    Whats your front lift measurement?
    Bluestorm mafia and maybe one or two other vices.
    My 150: http://www.pradopoint.com/showthread...-D4D-automatic
  3. #135
    I'll measure them this afternoon... centre of wheel to under guard ?
  4. #136
    Join Date
    Sep 2009
    Location
    Toowoomba/Sydney
    Posts
    72
    Could you do the rear as well? Did you install them yourself or paysome one?
  5. #137
    Join Date
    Jan 2008
    Location
    Samford
    Posts
    6,019
    Bottom rim lip to guard is the standard that seems to be in favour. Ta.
    Stolen from the 120 measurements thread.
  6. #138
    As requested !
  7. #139
    In my driveway once driven and settled other is at workshop straight after fit
  8. #140
    Join Date
    Jan 2008
    Location
    Samford
    Posts
    6,019
    Thought as much. Do you have a diff drop in the front? Very high.
  9. #141
    Sure do
  10. #142
    Out of control poster! amts's Avatar
    Join Date
    Jun 2009
    Location
    Adelaide, SA
    Posts
    9,573
    Front needs to come down. It's about 3.5" lift. What is your droop measurement?
  11. #143
    Quote Originally Posted by amts View Post
    Yeh maybe... had similar heights in hilux and was grouse ... I'll throw caravan on and see how it sits... probably take front down 10 -15mm
  12. #144
    I measure droop this arvo
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
