2.8L DPF Regen tracking
  • #46
    Originally posted by carco View Post
    Right now i’m Following (at distance) a stinking white smoke billowing hilux, highway south of Taree.
    i would imagine there would be a lot of toxic compounds in that white smoke , i would keep my distance.
    • #47
      My car has been back to toyota 7 times for DPF issues, blowing white smoke, high fuel consumption, the last time it was in it had a manual burn button installed, useless really just stops me having to go back to toyota to have a manual burn done. You just cant do a manual burn the DPF has to be blocked for you to be able to switch it on. Toyota did turn my DPF light on the dash on so when my car does initiate a burn the DPF light on the dash flashes during the burn. My car is doing a burn every 200km and stays on for approximately 20 kms. Toyota will be seeing my car again real soon.
      • #48
        With an auto, how do you know when its doing a burn? I assume that the hilux is the same? we have a hilux as a work vehicle and i wanted to see how often it does a burn.
        • #49
          Idle speed will be higher at about 900 rpm for an auto, (1200 for a manual I think). If you can watch fuel consumption it will be higher than normal. If you are stationary and you feel gas coming out of exhaust pipe it will be REALLY hot. Otherwise it is hard to tell. Normal seems to be a burn every 200 km to 300 km for 10 km to 30 km. More frequent if towing.
          Prone
          2018 Prado 150 VX Auto
