Installing OBD2 bluetooth scanner on M-OBD Prados
    Originally posted by bprado View Post
    Mine just arrived today and I installed the app seems to all work fine on my 04 grande diesel hopefully there might be more that we van get to display. Very good find I say.
    What is your build month?
    There is one other who reported that it isn't working with his pre Sep '04 1KZ.
      Got mine last night, very easy install and work as advertised, just need to play with the settings and features to get the most out of it.
      Found one error code already: P0743 - Powertrain (Torque converter clutch circuit electrical) this sounds like it might the lock up switch I installed.
      Thanks Andrew
        Mine is a November build
        04 grande, bilstein A712 &A713 kings spring , 3 inch exhaust chip it chip, XGT lightforce, 1 x lightbar, Sov Bar, Tigerz11 Grande winch with rope, Oricom UHF.
          Thanks Andrew
          That sounds promising re: the error code. Can you clear it?
            Thanks for confirming. Seems that it is getting quite evident that this device and special text string won't work on pre Sep 2004 1KZ.
              Iv just worked out how to get my auto temp to work it even has a intake temp. I have to say I love this app hopefully we can find more things to display and guys with pre Sep build can get it working. For a total of about $20 it's a very good find that's why I love this forum
                Managed to score a 2nd hand Android phone for nada (I'm an iPhone user), so I ordered the OBD11 Bluetooth dongle last night and downloaded the Torque Pro App in readiness...
                  How did you do this, any guidance would be appreciated? So far the only temp I have is engine.
                    You go to settings, find Manage extra PIDs/Sensors. Then tap the menu button and tap on ADD PERDEFINED SET. Tjen a couple of list will show up I taped on other as it was all ready in there. Once tapped it will show up on the screen then all you have to do is find it on your gauge screen it would be Transmission method 3 the other 2 does not work. Hope this makes since
                      Originally posted by cjaydee View Post
                      Is your 1kz pre or post sept 04. Mine is pre and i am having no luck reading ecu. Tested pro version and elm on another car and all is fine any suggestions??
                      Confirmed that the OBD2 dongle is now working on pre Sept 04 1KZ when using the larger dongle on the left. The smaller dongle on the right was either dodgy or not compatible.
Name:	OBD2 dongles 2.jpg
                      In the vehicle profile settings, you may need to tick the checkbox "Use alternate OBD header"
                      amts
                      Ninja Poster.
                        Hey guys,
                        I really cannot understand why it doent work in my Prado. (6 gear manual transmission KDJ120L-GKFEYW built at 12/2004)
                        Shouldnt it work since I have the 6 gear manual version?? Anyway, I have also tried the suggestion of amts...
                        I am using the Torue Pro and the tongle is the usual blue ELM 327. I have done all that amts has suggested (adding the ATIB 96 \n ATIIA 13 \n ATSH8213F0 \n ATSP4 \n 0100 in the very advanced settings)
                        Can someone help me?
                        spyrosfly
                          Originally posted by spyrosfly View Post
                          Hey guys,
                          Did you try without the special text string?
                            Yesssss!!
                            That was my 1st attempt since it is supposed to work without any configuration (6 gear manual)
                              [ATTACH=CONFIG]22306[/ATTACH]
                              [ATTACH=CONFIG]22307[/ATTACH]
                              I have the correct dongle and have ticked that checkbox, still unable to connect. The 'Adapter Error Count' kept climbing so maybe I have a dodgy dongle??
                                Maybe should try mine to check.
