joe's 1kd-ftv d4d j95 build
  • joe's 1kd-ftv d4d j95 build
    Hey Prado people! I am a bit new on the forum so i thought i'll introduce my build as i know it may be a bit scarce.
    My pride and joy is a 1998 White (basic) Toyota Prado j95. She had an old tried 1kz-te with and auto tranny and bad pump. God had grace with me and i came across a crashed 2014 3.0 hilux. It was still starting and driving, (more nose damage), so i decided to go through with the conversion. Too bad there was very limited info for this conversion on the web. There was this one thread that helped, on this forum but the guy converted using his exsisting gearbox.
    This is what drived me to the build (and the 172hp lol) and i promised to post the info on completion.
    The post may be a bit slow as computer time is against me but i will try to be steady.
    pics before and after the transplant..im not a professional but i am willing to discuss whatever you fine ppl wanna ask.
    I call her my PRADUX
      So you transplanted both the engine and the gearbox? What issues did you run into? I'm sure there will be a lot of members on here interested.
        engine and autobox actually. full engine harness brain etc
        i want to do a write up
          so firstly the engine and tranny fits in pretty well.
          as my friend said you have to reuse the both the engine and transmission mounts. as the engine in the hilux sits higher and further forward than the Prado. I retained the hilux engine mounts as my 1kz mounts were shot. so as a result the engine is about an inch too high so i had to modify the scoop to fit the engine cover properly (tidious)
          also ive noticed that there is an brace from the engine block to the tranny at the bottom of the engine. the 1kz does not come with this..so maybe if you are using the prado engine mounts you may have to remove these braces as they may touch the front diff.
          when using the prado tranny mount you will have to slot out the top where the bolt holes are because the hilux tranny bolt holes are slightly taller. but this is a must as the hilux tranny mounts causes the tranny to sit too high causing it to touch the top of the tunnel.
          so once you get that out of the way she bolts in just fine.
          rear drive shaft also has to be lengthened about 4" and front
          shortened about 2"
          also the prado shifter is linkage and the hilux is cable. so i bolted the hilux shifter in the position of the old shifter and routed the cable through the hole to the front of the shifter in the tunnel and attached it to the bracket on the tranny.
          Disclaimer - I STRONGLY DONT RECOMMEND THIS CONVERSION IF YOU DONT HAVE THE ENTIRE HARNESS FROM THE DONER VEHICLE.
          which brings me to wiring
          wiring was a bit tidious..not to get the engine working but to adapt the prados controls to the hilux harness.
          yes i completely ripped out the entire prado harness leaving only the rear harness intact because the 2 things the prado had that the hilux didnt were a rear diff locker and a rear wiper.
          i took this opportunity to repaint the engine bay and clean up the interior
            more picsClick image for larger version
              more pics
                That's a big job well done. Pradofreak fitted a D4D here. If you search his user name and PradoPoint you should find his build thread.
                Here:
                http://forum.australia4wd.com/index....84-pradofreak/
                http://www.pradopoint.com/showthread...0-series-prado
                http://www.pradopoint.com/showthread...D4D-Conversion
                http://www.pradopoint.com/showthread...D4D-conversion
                  Agree , great job Madantz much more than I would attempt or could do.
                  Alan
                    Thanks guys. And as pradofreak said the conversion is well worth it. I was climbing some 60° hills this weekend. In 2wd she pulls off from a dead stop effortlessly. I couldn't be happier.
                      Bigup on the build Madantz. Let me know if you can link up an engine for me in TT to ship to Jamaica!
                        No prob likklebit send me a message with all the details of what you looking for. Engine tranny harness etc. 2.5 or 3.0
                          hey guys i threw on some 35s
                            Tidy job on the conversion. Loving how well integrated the gauge display and shifter surround has turned out. Looks factory from the inside.. I bet you're happy with the job! well done!
                            [B]robe0455[/B] 2002 KZJ95 Prado - Bilstein/TJM 2" Lift, Glen_EP Front Disconnects, D697's, Platform Rack, TJM Roof Top Tent, Snorkel, HID's, Sliders, Underbody Protection, Dual Batteries, Boost Mods, Catch Can, Gauges and some other bits and bobs...
                            [URL="http://www.pradopoint.com/showthread.php?38366-Mar-s-95-Series"][U]*Build Up[/U][/URL]
