oops. Yes 13.5-13.6v charging. By the way I am using a "Kickass"" VSR
Dual battery setup for 2.8 1GD
Originally posted by robby4675 View PostThanks guys i'll look into the Traxide. Is the factory battery a throw away item?Cheers
Thanks guys, really appreciate the wealth of knowledge on this thread, after reading the whole thing I'm looking at the SC80 VSR. Just need to work out which 2nd battery i'm gonna go. Any recommendations? Checked out the Optimas on the weekend whilst at Autobarn picking up a pioneer platform. The optimas look the biz but low amp hours?? Maybe a marine pro?
For those looking at putting in a dual battery system, I was just discussing a problem with someone, he has had a dual battery system installed in his car, the installer fitted an SSB 100Ah battery, and he fitted a booster diode. He found down the track that the SSB capacity was dropping and on examination the battery had swollen.
I looked up the battery and it said heavy duty suitable for starting application etc, when I looked at the specs I was very surprised to see the max charge rate specified as 12.5A and regular charge rate 5A. This battery may be rated for starting purposes etc but I certainly would not be connecting it directly to an alternator as the recharge current of the battery when it is low is most likely going to be well in excess of 12.5 amps. I had a quick look at a couple of other of their AGM batteries and they had similar specs.
I would be only using these batteries with chargers that can limit the current to below the 12.5 amps, preferably 5A max.
LeighLast edited by LeighW; 28-11-2016, 11:35 AM.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
As I posted earlier I have been seeing from 12.25 – 12.40v at the cranking battery of a morning. I’ve been testing the Traxide SC80 isolator for a couple weeks now and see 12.50 – 12.60v with the SC80 using it’s ‘shared mode’. Up until now I have been using a Redarc BCDC1220 exclusively.
The alternator on my 1GD seems to put out around 13.80v on average. On a cold morning I saw 14.0v (only tiwce) and a hot morning as low as 13.65v. The state of charge of the batteries seems to have little effect and it’s mainly the ambient temps that effect the output.
If I switch the SC80 over to ‘storage mode’ it isolates like a traditional VSR and will get my Optima up to 12.75 – 12.80v easily enough.
After talking to Drivesafe I did expect the cranking battery resting voltage to come up using the SC80 but was genuinely surprised at how quick I managed to recharge the Optima AUX with the SC80.
One test I (accidentally) started with just under 11 volts in the Optima, I went for 2 x 10 mins runs and left the car off (and fridge on) for 30 mins then read 12.47v at the AUX. It ran down again to 12.28 over a couple of hours and after 1 x 20 min drive it was back up to 12.55v. Not a very precise test I know, but using the BCDC and assuming max 20A output the whole time, I couldn’t have put back in more than approx 15AH.
For those that stop and camp or are heavy power users I would say consider the Traxide dual purpose isolator on their Prado. I’m only a light user and find it works well, the SC80 is pretty handy in being able to switch modes and I don’t know why Drivesafe doesn’t push his product more!Cheers
Something to watch. After a recent trip I noticed that the 2nd battery tray in my 2.8 had been in gentle contact with the hose to the intercooler as shown by a slight mark in the dust. It happens as the motor moves slightly on its mounts. The tray is a Supercheap one and obviously is a fraction too long so it will be replaced ASAP!
Originally posted by LeighW View PostFor those looking at putting in a dual battery system, I was just discussing a problem with someone, he has had a dual battery system installed in his car, the installer fitted an SSB 100Ah battery, and he fitted a booster diode. He found down the track that the SSB capacity was dropping and on examination the battery had swollen.
Leigh
Leigh
just wondering where you found the specs on that SSB battery???
I have the below battery from what I can find the specs are far different from your numbers?? & cant really understand how a 12v battery would get charged to 100% and only 12.5v???
Part Number HVT-70ZZD
BATTERY TYPE AGM VRLA - Cyclic Use
REGULAR CHARGE 10.0 Amps
MAX CHARGE 29.4 Amps
Maximum recharging voltage is 14.6 Volts.
http://www.superstart.com.au/Product...19/Default.asp
G
Their Website.
The specs will vary from battery to battery, even with the specs you have quoted, if the battery is regularly discharged to 50% SOC how are you going to limit the charge current to 10A or even 29.4 amps when charged directly off an alternator?
Even if you could limit it to 10A why would you want a battery that is going to take 7+ hours to charge from 50% SOC, not much use in a touring situation where you may be depending on recharging the battery in a typical days drive?
CheersHKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
I have no agenda to push regarding VSR, diodes or BCDC. I'm not in the industry and cant give a rats about all the hoo harr as long as the beer is cold, but i am very very impressed with the SSB battery I have been running. With a 1 hour return commute my 40l fridge is self sufficient in the car and no issue over the weekend even if that car is not used with no solar asistance.
Do you have the model number of the battery that experienced the swelling and overcharging?
im also wondering how the F you would get a 12v battery charged with a max charge rate of 12.5v?? - i almost thought you made a typo and meant 13.5v
G
Firstly my point was to alert those installing a dual battery system that some batteries may not be suitable for direct charging off an alternator, or high output DCDC chargers for that matter ie check the suitability of the battery for the intended use.
Secondly where did I write "max charge rate of 12.5v"
Thirdly I'm not pushing anything as you put it as I have already made it quite clear boosters are not an option for the 2.8.Last edited by LeighW; 02-12-2016, 01:11 PM.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Originally posted by LeighW View PostFirstly my point was to alert those installing a dual battery system that some batteries may not be suitable for direct charging off an alternator, or high output DCDC chargers for that matter ie check the suitability of the battery for the intended use.
must be a Friday
beer o clok me thinks
always fixes the muddled head from a long working week
Sorry I can't recall, the guy told me the number over the phone but I didn't wright it down,
he'd changed it for a Century deep cycle battery and had had any issues with that to date.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Originally posted by 120D4D View PostAs I posted earlier I have been seeing from 12.25 – 12.40v at the cranking battery of a morning. I’ve been testing the Traxide SC80 isolator for a couple weeks now and see 12.50 – 12.60v with the SC80 using it’s ‘shared mode’. Up until now I have been using a Redarc BCDC1220 exclusively.
While I already have a number of new Prados fitted out with my isolators, and the isolators are doing there job, your feedback is the best info so far, because you have had the experience of already having a DC/DC setup in your new Prado and being able to compare the two types of charging systems.
The real test will come when you do that longer trip you are planning.
Even though you are doing lots of short trips, the SC80 is still charging and more importantly, conditioning your cranking battery.
By the time you go on that trip, because your cranking battery is not only kept in a higher state of charge, because the way the SC80 allows the auxiliary battery to continually condition the cranking battery. Over a period of time, this continual conditioning of the cranking battery increases the cranking battery’s capacity and in most case, increases it back up to the battery’s original capacity when new.
So when you go on that trip, you will now have around twice the usable capacity you had with your DC/DC setup.
Even if you still only use the same amount of battery capacity you use to use with your DC/DC setup, when you go for a drive, you will, as you have areal mentioned, replace used battery capacity much, MUCH faster then any DC/DC setup can do.
As for promoting my gear, most of my work comes from word of mouth referrals, and feedback like yours, and this keeps me flat out.
Again, thank you Michael for the excellent feedback.
