Kakadu suspension upgrade - any successes?
    Originally posted by Orrsom View Post
    Cal was a great help for me. Email, phone or text response to all questions. He told me to get the installers to call him direct if they had any issues or questions. So purely from my experience, I would not hesitate to recommend them. Just my two cents.
    What is the current suspension height and droop measurements?
      The front is 793mm drivers side and 800mm passenger side.
      The rear and Neutral height is 830mm drivers side and 820mm passenger side.
      High setting
      870mm Drivers rear and 855mm passenger side. This is measured from the bottom of the rim to the underside of the wheel arch through the centre of the rim. The front remains the same.
      I've been told to adjust the KDSS on the prado it's slightly different to the 200series. Instead of jacking the body higher on the low side with the bleed valves open, you actually jack the high sided axel into the wheel arch with the valves open then tighten. I'm told you can get it within 5mm or so. Otherwise Toyota can attach the pump and add more fluid and reset the level at my next service.? Will give the jack a go first.
        Different service to this one: http://www.pradopoint.com/showthread...ght=caloffroad
        Anything ever come from this Zerosecta?
          Yeah, wow. Sorry to see that, completely different service to me.
            Zero ripped the lot out
            http://www.pradopoint.com/showthread...-adjuster-kind
              Expensive paper weight...
                Hi winstonwolf , in Brisbane you could call zordo or pm him. He is a forum member . I believe Aussie Andy has installed the cal offroad gear with king springs so you could pm him to ask about pros & cons as he's very knowledgeable & helpful
                Cheers Matt
                Sent from my SM-J110F using Tapatalk
                Rig build here
                  Can anyone tell me how I trick the rear airbags on the 150 kakadu please ? any photos ?
                    It's the same as for the 120. Space down the height sensor with washers.
                      What Amts said..!
                      [IMG][/IMG]
                      [IMG][/IMG]
                        Thanks Amts, I got 8mm spacers in their. Gave me 20mm lift. What's everyone doing ?
                          Hey Amts my drivers rear seems to be on a lean ?
                            Sorry, my crystal ball is broken. What did you do?
                              How many mm of spacers are guys putting in to achieve desired lift ?
                                Trial and error.
                                Keep adding until you get the lift you desire.
