No problems,
If you did want to do it yourself
http://www.ebay.com.au/itm/BNC-TNC-C...wAAOSwX~dWiSOk Crimpers
http://www.ebay.com.au/itm/FME-Male-...MAAOxyoMxSIX0O FME connector pair
http://www.ebay.com.au/itm/RG-58C-U-...MAAOSwYGFUrqPd Coax cable
Your UHF antenna should of come with a PL259 jack (UHF antenna plug), just crimp/solder that onto the other end of the "extension cable" you make up. Make sure you either slide a bit of heat shrink or wrap some electrical tape over the FME connector to both keep the connection clean and insulate the ground side.
Andy
Andy
