Page 5 of 6 FirstFirst ... 3456 LastLast
Results 49 to 60 of 62
  1. #49
    Advanced Member Razorback81's Avatar
    Join Date
    Sep 2012
    Location
    Lewiston SA
    Posts
    561
    yes i had to do the same to mine when we first went to Mt Dare
    started hearing a ting ting ting at wheel speed
    but great news is the shafts have NO damage from the thousands of rocks that's been thrown at them !!
  2. #50
    Join Date
    Sep 2009
    Location
    Burpengary QLD
    Posts
    348
    I finally managed to get some photos of shock protectors a talented mechanic/engineer mate of mine has used for years.
    As background, he spends much of his time building rally cars for serious competitors in variety bash type rallies. These are not factory supported late model EVO type vehicles, they are 20+yr old Holdens Fords, etc. that see some pretty harsh treatment. His own XW Falcon has completed every stage of every rally for the last 29yrs, including one of the few unassisted 2WD crossings of the Simpson (he never attached a snatch strap to it all trip). It is a work of engineering art and has already been acquired by a local transport museum when (if) he retires it.
    Anyway, in his experience he has seen shocks literally sawn in half by rocks due prolonged high speed on gibber roads. He tried metal guards long, long ago but all succumbed to the pounding of rocks, as has been witnessed on the ones mentioned here; all ended up being bent back onto the shock eventually, then being pounded into the tube with the end result that they did nothing but transfer the beating to the shock . This was his solution. The material is heavy duty conveyor belt rubber bolted onto brackets in a "U" shape to allow some flex and rebound. These have to be custom fitted, either to brackets welded or otherwise attached to either the diff or shock mounts etc. His "testing" of a fitout consists of smacking the cover with a 6lb club hammer. This approximates a reasonable sized gibber hitting at high speed. If the rubber deflects but doesn't hit the tube, all's good. His other tip is to sand and repaint the shocks flat black for better heat dissipation (on the downside, you lose the bling, but it depends whether you want show or go!) He has had the same guards on for many years now, the ones shown have been on his Rangie (easier to get under for photos!) for probably 10yrs, but as you see they don't get bent up and buggered!
    Just some (proven) ideas for the DIY types out there!
    cheers
    Steve
    Attached Images Attached Images
  3. #51
    Administrator Piggy's Avatar
    Join Date
    Feb 2006
    Location
    ADL, SA/ BNE, QLD
    Posts
    4,707
    Blog Entries
    4
    Nolathane or urethane sheet works better than conveyor belt rubber. Or HDPE or Nylon plastic sheet (4-6mm).
    We use it as underbodies on the rally cars I'm involved with. This survives a fair bit of what we throw at them.. rocks at >220 kmh on gravel eat thru pretty well anything in time.
    Alloy, steel, plastic, rubber you name it.
    I recall a rock literally coming thru the floor on one of the Factory supported Honda Jazz rally cars... took out 2 layers of underbody and then the floor pan.....💥
    I've got urethane shock protectors on my 120. Lasted fine.
  4. #52
    Join Date
    Sep 2009
    Location
    Burpengary QLD
    Posts
    348
    Hi Piggy, how much does a sheet of urethane cost? Last time I bought some rod stock it was $$$$$$!
    Main thing is to make sure that it doesn't touch the tube when hit otherwise you just end up with a dented shock.
  5. #53
    Join Date
    Feb 2006
    Location
    ADL, SA/ BNE, QLD
    Posts
    4,707
    Blog Entries
    4
    Depends where you buy it from. I'll have a dig around the workshop and see if I can find a price. We bought about 10 2.4 x 1.2 sheets last time as we had numerous builds underway.
  6. #54
    Join Date
    Jul 2014
    Location
    Brisbane
    Posts
    292
    Rear Stone Guards for Ironman Shocks
    I've been asked to revise the design to provide more clearance for the massive Ironman rear shocks. I've made up a couple of sets for the 120 and 150.
    I have test fitted to a set of new shocks that have just come back from a trip to the Simpson. They cop a bit of damage.
    If there is enough interest I'll make a few more.
  7. #55
    Member shonky 150's Avatar
    Join Date
    Dec 2014
    Location
    Hoppers crossing,VIC
    Posts
    102
    Put me on the list Tin.
    thanks
  8. #56
    Lurker
    Join Date
    May 2016
    Location
    Warrandyte, Victoria
    Posts
    22
    Quote Originally Posted by Tin175 View Post
    I would be interested too mate. I should be receiving my revalved ironman suspension from Mark very soon. Be great to have the guards installed at the same time.
  9. #57
    Member SimpleSi's Avatar
    Join Date
    Jul 2012
    Location
    Brisbane
    Posts
    228
    I'd be up for a pair Tin
    2010 150 GXL Ebony Diesel | ARB Delux Bar | ARB Bashplates | GME 3450 UHF | Bilstein/Dobinson lift | SA LED Lighting 185W Spotties | Bridgestone D697LT | Wet Seat covers | LeighW's Voltage booster | Tin75 Pet barrier | 3D Mats'n'boot protector | Onboard ARB CKMA12 Compressor | Rhino Pioneer Platform | Roadsafe Recovery Points | Airtec Snorkel
  10. #58
    Count me in for a set for a 120.
  11. #59
    Lurker
    Join Date
    Dec 2010
    Location
    Adelaide
    Posts
    3
    Add me to that list also Tin!
    07 GXL V6
  12. #60
    Join Date
    Jul 2015
    Location
    Near Adelaide
    Posts
    111
    I'm interested also.
    Cheers, Nova
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
