Tool kit in back door?
    Hi, just bought a 150 series Prado and it's missing the tire jack and tool kit.
    Anyone know where I can get these or have any spare lying around? I imagine they would be expensive to buy straight from the dealer?
      Did you buy it from a dealer? I'm fairly certain that a jack and the jack handles have to be supplied. You could try a toyota wreckers.
        Nope not from a dealer bought it privately. Found a tool kit and jack at a wrecker but they want $170, is that a reasonable price?
          Who doesn't have a jack when they sell a car? You can probably replace the bottle jack for a lot less at Repco or Supercheap. It really depends how badly you want the genuine Toyota bits to fit in the door. There were a couple of things missing from mine when I bought it but the dealer let me pinch the missing items back from my old Prado that I was trading in. It was a 90 series but the spanner, etc were the same as the 150 series.
            Other than using the lever bit on the wheelnut spanner to pop off the caps I dont know that I have used the other tools. Look at a decent 3.5 or 5 tonne hydraulic jack and some better quality tools including a 1/2" breaker bar.
              Originally posted by JimmyC View Post
              Nothing missing from photo 1. Compartment is empty. Second photo appears to be missing screwdriver, spanner and (hard to tell from the photo) but a screw missing from one of the extension bars and a screw from the right angled jacking bar
              Old thread, but while I think the right-angled jacking bar screw seems missing there is an extension bar that does not carry any screw.
                Revisiting this, in my toolkit the right-angled jacking bar has two holes with only one threaded. The threaded, screw-bearing hole points toward the case when that is snapped into the case, so it makes sense you would not see it at all in the photo as its beneath.
                I have noticed the parts can rust especially if exposed to saltwater and not properly cleaned/dried after use. The screwdriver may fail to unscrew in a tight spot and the spanner may be required. I am for now keeping mine oiled because I had bad experience with a flat tyre where I felt using the spanner would simply break the screw head off.
