Hi all,
The Toyota Transfer Gear Oil LF SAE 80W-90 GL4 recommended for my model Prado's gearbox and transfer case is over priced so after extensive research and put in Caltex Easy Shift Manual Transmission Fluid SAE 75w-90 API GL-4 which is to spec and at a reasonable price.
However, I have found over the past year of driving the gear changing to be slightly knotchy. Can anyone recommend another gear oil which is to the same Toyota's specs but with a bit more viscosity as I am getting ready to change out gearbox and transfer case oils again and want to try a different oil. I looked at Fuchs but can't find any to the Toyota recommended specs of GL4.
I live in Darwin and it is a very hot climate here.
Thanks to anyone who has any experience in this area and answers my query.
