Bilstein struts and shocks: Lengths and Valving
  • #61
    Hey all,
    I’ve finally tracked down all the different versions of the D563 strut, valving is shown below;
    The BE5-E232 is the Hilux TRD spec strut, also known by the Toyota Tokico part number 48510-YWR01. Toyota have just slapped their Tokico sticker over the E232 sticker.
    The main difference between the E232 and the original D563-M0 is the rebound is higher by around 840N and compression is softer by around 880N.
    The D563-M2 appeared many years later after the M0 version, and you can see that within valving tolerance it uses the same rebound as the E232. I would say D563-M2, E232 and D563-Gen8 all use the same rebound shim stack. However, the D563-M2 still uses much higher compression than the E232.
    The soft compression of around 1500N has also been adopted in the latest D563-Gen8 strut for the new 2.8 Hilux. Note that the open length of the D563-Gen8 strut is limited to 555mm, as the double wishbone geometry on the new Hilux is different to its predecessor.
    While all of these struts are curiously regarded by Sydney Bilstein as Hilux spec struts, there is no reason they cannot be run in a Prado. As I have discussed in other threads, high rebound struts on the Prado when combined with around 660lb/in coils can dramatically enhance the off-road performance of the IFS. I myself am running the D563-M2 strut with a 675lb/in coil and it is brilliant in the rough stuff.
    However, the soft compression valving of around 1500N is of particular interest. Will this enhance the off-road performance of a Prado even more?
    Another clue in this valving jigsaw puzzle is the valving of Koni struts. The Prado specific 88-1712 has 3100N/1500N. The Hilux specific 88-1713 has 3500N/1500N. Both of these Koni struts fall in the same range of valving as the D563 struts above. The 88-1713 in particular looks to have almost the same valving as TRD spec. The purely hydraulic 88 and 90 series RAIDS have a hard earnt reputation in the roughest of corrugated conditions, so the soft 1500N compression may be an important factor.
    My on and off-road driving impression of the D563-M2 is very positive. Off-road in heavily rutted conditions on Fraser with soft 16psi tyre pressures, the IFS cycles brilliantly. On-road with 40psi, I can feel the front being slightly skittish on crappy bumpy sections of Brisbane roads. Lowering tyre pressures is the equivalent of lowering the compression valving, so for 40-60km/h in the sand and rutted stuff with low tyre pressure I doubt you’ll feel the difference between 1500N and 2200N.
    On corrugations at moderately high tyre pressures of at least 30psi, then I think you’ll definitely notice the difference between 1500N and 2200N of compression, and the lower compression (TRD/Koni spec) may be beneficial at moderate speeds.
    Higher speed driving in whoops will require higher compression to cope with bump outs.
    Hope you’re all enjoying your Bilsteins!
    on a side note with the konis the 88-1713 has a spring seat 10mm higher than the 88-1712 so this will raise the vehicle and unlike the bilsteins the spring seats are welded to the strut so cant be lowered ( like i assume you would have done in your prado) and koni have also just released a long travel 90 series rear for the prados, which is going to perfect for some of the serious touring rigs. we are waiting for our shipment at the moment.
    • #62
      Hi ollii,
      Interesting news about a long travel version of the 90 series rear. Koni unfortunately missed the long travel boat with the RAIDS, so I'll be interested to see what the new long travel lengths are. The original 90-5404 is also very similar valving to the 713 Bilstein, even softer rebound at closed position. This means it is not useful for a heavily packed up Prado which requires stiff coils and high rebound. Hopefully the valving has also been improved!
      • #63
        Hi ollii,
        yeah i haven't seen the specs yet so i don't know, but being adjustable the rebound could be set to help control the heavier vehicles.
        • #64
          Hey,
          The 95-5404 is 1060N/1600N at 0.52m/s at 0.0 turns (fully closed rebound adjuster), 2030N/1600N at 2.5 turns (fully open rebound adjuster).
          2000N rebound still won't be anywhere near enough rebound, 3500N is much more appropriate for the Prado rear. Such high compression is also only suitable for a low rate coil around 230lb/in maximum.
          Be interesting to see if the new 90 series has better valving.
          • #65
            Hi Whitey I have been re reading this thread for two days but unfortunately for me I’m no better off in the way being able to decide which bilsteins to buy for my 150 series GX. At the moment I think I’m going to go with Be5-A712 / 24-217897.
            I have some questions though. Will they be supplied with the correct bushes for my 150, as in a brief chat with someone at Bilstein Sydney he did not seem to be aware that 120 and 150 were different. I’ll be going with King springs but not sure which springs I should be asking for to match the suspension. The car will have steel arb bullbar, dual battery in the front. Bushskins bash plates no winch. Set of draws in the back.
            Any help you can offer would be greatly appreciated.
            • #66
              Email Mark / whitey (link in his signature) there was another set of big bore revalved Billies available...
              • #67
                Hey Pablo,
                The 712 is a mid ranged travel strut with not enough rebound or critical damping to be useful in the front end of a Prado. An off the shelf BE5-D563 combined with a King KTFR-101H is much more appropriate for the front end.
                The 897's are ok in the rear. A king coil in the rear is not appropriate for the coil bucket separation at the open length of the 897. you are better off running a longer free height of at least 410mm, so Dobinsons 327 minimum.
                As mj mentioned, there is a remaining single set of custom valved 60mm Billies for the Prado (in Brisbane), the only such beasts in Australia. You would also need custom made front coils for this setup, see here in post #86;
                http://www.pradopoint.com.au/showthr...utomatic/page8
                I've been ok'd by admin to have these put in the for sale section if your interested.
                Piggy
                Water pistol pilot.
                • #68
                  Has anyone had the valving changed in Bilstein shocks in the rear of their 120 series Grande?
                  Mine suffered from lack of rebound dampening during our Simpson Desert trip and I'm about to get them revalved.
                  I have the standard BE5-A713 installed, meaning they won't have the assistance from the spring during compression in the Grande model.
                  I'm thinking of getting the compression increased by 10% to help compensate for the airbags.
                  Any advise apart from replacing the springs (as I need the height adjustment) would be appreciated.
                  • #69
                    BE5-A713 is not a good shock for a Prado.
                    Poor valving and not suited for any lift on a Prado. Would cost a lot to have them re-valved. Just replace them with a better shock. Have a look through Whitey's amazing info on the suspension options.
                    Here are the details between the 713 and the Ironman whitey selected and valved:
                    http://www.pradopoint.com.au/showthr...nsion-Database
                    Bilstein BE5-A713 580 212 368
                    Ironman 45682FE 618 235 383 Foam Cell Pro
                    • #70
                      Change the rears to 24-217897.
                      • #71
                        Hi guys! Wow what info! Unbelievable. I'm going to take a huge chance and ask regarding a 95 Prado, as I was not able to get this info thus far. I carry 100kg on the roof, SS bulbar only in the front. Other than that very, light. Not much packing, more weekend warrior for camping and short overlanding stuff. Looking for cost effective solution. I can phone someone as I'm based in South AFrica. I've heard OEM 120 setup front to front 90 and OEM front coils 80 with OEM shocks rear 80 in rear 90
                        Can anyone comment?
                        Alternatively comparisons of 24-010047 vs B46-1004LT? I cannot get the LT version in South Africa where the first one is for the front of a 60 series landcruiser
                        • #72
                          Can anyone comment?
                          • #73
                            Hi Mark,
                            I have a 2011 GRJ150 Petrol with standard suspension which is very floaty and looking to do a 2" lift. The vehicle only has a nudge bar on the front and doesn't carry much weight in the rear. For some reason the Drop box links with the Bilstein valving is not displaying on your above post?
                            I was thinking of running the following combination.
                            Front Coil : KTFR-101T
                            Front shock absorber :24-173032
                            Rear Coil : KTPR-102T
                            Rear shock absorber : 24-217897
                            I also have a GRJ120 and run the above rear combo on this successfully. However on the front I run BE5-A712 with a 660Lb King spring which isn't so good.
                            Glad of your comments of what you think is a good combo for the 150 series.
                            Regards,
                            Darren Caldwell
