car idling too high when engine is cold
  • car idling too high when engine is cold
    Hey guys,
    First of all, thankd for letting me join this great forum. I bought a prado couple days ago and I love it.
    but lately it revs up 1500when I start it in the morning. I have to drive around for like 10 mins until the engine warms up and the idle revs slow down very slowly to normal 800rpm.
    It wasnt like that when I bought the car so it cant be the cooler weather. Ecu reset didnt change anything. Havent noticed any weird noises or funny behaviour of the car besides that and I didnt do any work on the car since I bought it
    im a bit worried cause I want to drive to brisbane in 3 days, could this be something seriou and how can I find out whats causing the problem?
    Thanks a lot for your answers!
    Cheers, korbi
    Check the idle up button isn't depressed.
    Graphite 2013 "Altitude" with an expanding wishlist.
      thanks for the answer. But then it should be revving up regardless of if its warmed up and cold and the revs shouldbt g down unless I press the button
      ill check it in the morninf anyway
        The car doesn't have a idle up button so its not that simple sadly. Anyone else has some ideas?
        Cheers!
          Normal operating revs. If the idle didn't drop by itself it would be different but nothing to worry about. Mine runs exactly the same.
          Ken
          3.4 GXL man 1997 petrol / gas, BFG mud tyres 265 75 16, front and rear camera, Jaycar 6300Lm LED 6.5" D/L * 2, 15W LED reversing/work light, diff breathers, 42mm lift, Rear Anderson plug, Dash cam, and way too much recovery gear for one vehicle to carry around. No more HID headlamps. No more Narva D/L.
            So yours idles at 1500 rpm for 10 minutes? Mine goes down with in 2 or 3 minutes
            I got myself some Big Horn Maxxis and was telling my landrover lover mate he said what size did you get I told him 265/75/16 he said I didn't know they came that small.
              Mine revs at about 1200rpm when cold. A couple of minutes driving and it drops back to normal.
                Stupid question but how do you do a ecu reset?
                  If the same a Patrol's, battery disconnect for >30mins. Makebsure you have your radio pin code BEFORE doing....
                  1999 Prado VX Grande White on Silver 3.4Ltr Auto
                    It does seem to idle high for a while especially if the car is being driven and the revs don't get below about 2000, it takes a while to drop down to the 750 - 800 Mmmmmmmmmm
                    Ken
