Aircon System Help
    Originally posted by gxl_d4d View Post
    Leaking evaporator. Replaced with a genuine denso unit. $800 all up including regas. Works perfectly.
    Hi mate where was that done
      Here are some pictures of my leaking evaporator from a 2008 GXL with climate control. Note the oil stains on the bottom third. I dropped off the Prado at an air con specialist Friday afternoon, they worked on it over the weekend and I picked it up Monday. They also replaced the TX valve while the dashboard was out and dessicant bag. 10 hours labour + $400 parts = $1,700. Works fine now.
      2008 D4D GXL
        HI gxl_d4d,
        I was just reading youre post and was wondering how you got on.
        I have a similar problem and have put it down to the evaporator unit, was thinking i might be able to do it myself as i have read it can be accessed through the glove box, and pulling out the dash is not required.
          Mine was a leaking evap. It had a pin hole leak on a cooling fin tube. Was just under $1000 for a new Denso unit installed.
            I recently had similar symptoms with my A/C. I had a local mechanic regas the system, but within a few weeks the problem reoccurred.
            Wanting to get through christmas, 2 birthdays, and 3 car regos , a big A/C fix wasn't on the cards just yet. My mechanic suggested I try some STOPLEAK (available through Bursons) and another regas. 4weeks later, so far so good.
            Hopefully the dye from the first re gas has left its mark and will stay until the end of summerClick image for larger version
              Red devil radiators at archerfield.
                Originally posted by lovinmyprado View Post
                HI gxl_d4d,
                That's only true for the non-climate control type with the twist knob for the temperature setting like the GX. If it's climate control with the LCD display then the dash has to come out.
                2008 D4D GXL
